First time at the track with BFGs
Old Oct 31, 2006 | 09:51 AM
Outkast95LS's Avatar
Default First time at the track with BFGs
Going to the track this wednesday for the first time with my 225/50/15 BFG drag radials. Any tips on what i should launch at? Also, should i go into the water pit and do a burn out to warm up the slicks?
I was initially going to go into the water pit, and do a 2nd gear burn out. And try launching at roughly 5500RPM while preloading so i don't bust my axles.
Anyways, set up:
Stock LS
t3/t4 .57 trim
3'' dp
38mm tial wg w/ 11.6 psi spring
Omni power sport coilovers, 10k front, 12k rear
Old Oct 31, 2006 | 01:30 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: First time at the track with BFGs (Outkast95LS)
drop your PSI to about 10-12psi... take it to 6k'ish .. preload it and ip away...
thats how i do my BFG's...
1/8th ran 8.0's in my LS-T in a DC with 100lbs tool box....
and yes WARM THEM UP....
2nd gear burn out... get them warmmmmmm BFG's like it that way!
Old Oct 31, 2006 | 06:00 PM
blackeg's Avatar
Default Re: First time at the track with BFGs (S@nt0s)
definately warm them up! i run mine on 10 psi and probably do my burnouts for 6-8seconds before each run.
id start lower though, maybe like 4000 for launch rpm and go from there
Old Oct 31, 2006 | 06:02 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: First time at the track with BFGs (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">definately warm them up! i run mine on 10 psi and probably do my burnouts for 6-8seconds before each run.
id start lower though, maybe like 4000 for launch rpm and go from there</TD></TR></TABLE>
4k i promise it will fall on its face!
Old Oct 31, 2006 | 06:09 PM
I launch at 4K, and it sorta bogs already. But when i launch at 4500, i spin. I'll probably start off with 4500 launch, then proceed from there. I'll run tire pressure at 15psi, then lower it where i see fit.
Old Oct 31, 2006 | 06:10 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS &raquo;</TD></TR><TR><TD CLASS="quote">I launch at 4K, and it sorta bogs already. But when i launch at 4500, i spin. I'll probably start off with 4500 launch, then proceed from there. I'll run tire pressure at 15psi, then lower it where i see fit. </TD></TR></TABLE>
sounds good.. try preloading it some more.....
Old Oct 31, 2006 | 11:12 PM
ALL_MOTOR_FKR's Avatar
sorry to jump in but what is preloading,and how is it done???
Old Nov 1, 2006 | 11:21 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (ALL_MOTOR*Eg6*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL_MOTOR*Eg6* &raquo;</TD></TR><TR><TD CLASS="quote">sorry to jump in but what is preloading,and how is it done???</TD></TR></TABLE>
yank up on your ebrake and rev up to RPM wanted to launch at... SLOWLY.... pull the clutch back when you feel the dip in the rear.. you are Preloading... this is to take some stress off the drivetrain so there isnt as much of a sudden shock to it when you come out the hole
and as you are about to take off you drop the ebrake of course.... there have been times when guys have not fully dropped them and wondered why there felt slow or smelled brakes..
Old Nov 1, 2006 | 11:46 AM
Default Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">yank up on your ebrake and rev up to RPM wanted to launch at... SLOWLY.... pull the clutch back when you feel the dip in the rear.. you are Preloading... this is to take some stress off the drivetrain so there isnt as much of a sudden shock to it when you come out the hole
and as you are about to take off you drop the ebrake of course.... there have been times when guys have not fully dropped them and wondered why there felt slow or smelled brakes.. </TD></TR></TABLE>
Going to the track in a couple hours. I'll post up how i did..
Old Nov 1, 2006 | 12:38 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Outkast95LS)
palmdale???
Old Nov 2, 2006 | 12:23 AM
Nah, Infineon.. i'm from the BAY AREA
Old Nov 3, 2006 | 10:01 PM
drillr00's Avatar
How much does it cost there?
Old Nov 4, 2006 | 12:10 AM
Default Re: (drillr00)
25 bucks to run wed night drag, 15 for high school students.
h2b_196_whp
Feb 23, 2014 05:18 AM
jsw_1986
May 1, 2009 03:19 AM
sircrxracer
Jun 13, 2004 02:40 PM
streetlvlhatch
May 11, 2004 10:49 AM
streetlvlhatch
May 4, 2004 10:31 PM
