Analyze my slips!! High traps!!!
Old May 1, 2004 | 01:48 PM
streetlvlhatch's Avatar
Default Analyze my slips!! High traps!!!
I went to the track last night and only managed two runs. I just recently purchased bfg drag radials and this was my first time on them. i have an ls/vtec turbo with 340 whp at 14psi.
1st run-
60'...2.183
330...5.976
1/8...8.815
mph...86.59
1000...11.220
1/4...13.196
mph...115.01
2nd run
60'...2.020
330...5.704
1/8...8.539
mph...87.15
1000...10.964
1/4...12.962
mph...114.01
12.9 @ 114.5
The first run i launched at 9 psi and switched to 14 at 3rd gear.
The second run i ran 11 psi the whole time.
Any advice on lowering my times. It seems like my 60 ft is ok at 2.0, but my 1/8 mile time is still like 8.5 what is the deal?
Also i am on an ls transmission and i basically maxed it out in 4th gear at the end of the track. Is this a good trans for my setup. I was under the impression that you want to max out 4th gear at the end of the track. I am shifting at 78-8000 also.
Modified by streetlvlhatch at 5:42 PM 5/2/2004
Old May 1, 2004 | 01:54 PM
DIRep972's Avatar
Smarter than you
Default Re: Analyze my slips!! High traps!!! (streetlvlhatch)
8.2 is a pretty good 1/8 mile to only run a 12.9 @ 115 in the 1/4... you could run a 12.9 @ 115 w/ only an 8.6-8.7 in the 1/8 cause you just carrying the mph.. thats just wierd that you ran an 8.2 and only pulled a 12.9 w/ all that mph.. Should at least be 12.5-12.6ish
Old May 1, 2004 | 03:38 PM
Default Re: Analyze my slips!! High traps!!! (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">8.2 is a pretty good 1/8 mile to only run a 12.9 @ 115 in the 1/4... you could run a 12.9 @ 115 w/ only an 8.6-8.7 in the 1/8 cause you just carrying the mph.. thats just wierd that you ran an 8.2 and only pulled a 12.9 w/ all that mph.. Should at least be 12.5-12.6ish</TD></TR></TABLE>
yea thats why im confused about the times. wierd!!
Old May 1, 2004 | 04:27 PM
tobyboom's Avatar
Thats even odd to me... On my 13.1 in the 1/4, I clocked an 8.1 at the 1/8th point. But my cars gearing sucks *****.
But my traps were NO WHERE near that high. I dunno man.
Old May 1, 2004 | 08:48 PM
95b18civ's Avatar
your 2.0 60 ft times seem high, how much wheel spin you got. my b18b1 i pull 2.2 60ft times, about 175 hp total.
Old May 1, 2004 | 09:38 PM
b18cx's Avatar
Default Re: Analyze my slips!! High traps!!! (95b18civ)
Your 60' time is kinda high. Would like to know your 330' time, sounds like your loosing traction in the first half and making it up on the top end with the mph.
Old May 2, 2004 | 01:42 PM
Default Re: Analyze my slips!! High traps!!! (b18cx)
bump
Old May 2, 2004 | 01:55 PM
AROD's Avatar
sounds about right i have a ls , i pulled same MPH, my 60ft was 2.20 , i just made the rest at top end.
Old May 3, 2004 | 03:01 AM
anyone?
Old May 3, 2004 | 03:08 PM
someone help!!
Old May 4, 2004 | 11:08 AM
racinskittle's Avatar
your 60's seem good with street tires. Do you bog out at all at the beginning of your run? Although the 1/8 mph seems high as well (which would mean no)
Are you cautious off the line and then just slam the gas down and spin through 1-2- and most of 3??
Old May 4, 2004 | 12:13 PM
RaceProfessor's Avatar
Default Re: Analyze my slips!! High traps!!! (racinskittle)
Gearing appears to be the culprit. First and second are extremely long. B16 tranny should help. Just need to shift to 5th.
Old May 4, 2004 | 12:24 PM
DIRep972's Avatar
Smarter than you
Default Re: Analyze my slips!! High traps!!! (RaceProfessor)
For some reason I thought you had typed an 8.2 for the 1/8.. in actually it was an 8.5... 8.5 1/8 to a 12.9 1/4 is pretty dead on.. Did you edit that later?
Old May 4, 2004 | 02:18 PM
b16ahybrid's Avatar
225/50/15's ?
Old May 4, 2004 | 06:03 PM
maxpsi's Avatar
Default Re: Analyze my slips!! High traps!!! (b16ahybrid)
My suggestion is to not be switching boost pressures. Yes, it is a good solution to traction problems, but it is only a simple fix. I think you should invest in slicks/lightweight rims, suspension, and axles/clutch. Launch hard off the line and the end result will be some times that better resemble a car trapping 114 mph.
Modified by maxpsi at 1:54 AM 5/5/2004
Old May 4, 2004 | 10:31 PM
Rowdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor &raquo;</TD></TR><TR><TD CLASS="quote">Gearing appears to be the culprit. First and second are extremely long. B16 tranny should help. Just need to shift to 5th.</TD></TR></TABLE>
I agree with this idea the most.
Its like the 12 second club in here eh?
Charles B.
Jun 3, 2004 10:22 PM
streetlvlhatch
May 11, 2004 10:49 AM
boost fed ls
Apr 12, 2004 04:41 PM
boost fed ls
Apr 4, 2004 10:42 AM
B17aTrbo
Oct 27, 2001 04:44 AM
