Finding gear ratios
Old Oct 22, 2011 | 07:55 AM
mr sim's Avatar
Default Finding gear ratios
Hi guys can somebody explain a simple way to find out what my best gear ratio is for drag racing 1/4 mile
Or link me to a post please
Say I have 600hp it's 4wd 6 speed box and 17inch wheels how do I figure out what ratios give best acceleration over 1/4 mile
Thanks
Old Oct 22, 2011 | 08:01 AM
h22apwrd95's Avatar
Default Re: Finding gear ratios
You will need overall tire height and final drive ratio used with your max rpm per gear to figure out what your tops speed is in each gear. Plot that for each gear. Then look at your dyno graph at the power curve and see where you want your car to stay between while shifting. You want to try and keep the engine in the area where there is the most area under your power curve. That would be the best way to hypothetically apply power. But I am guessing you may be working with a limited number of gear ratios available in the 4WD transmission.
Old Oct 22, 2011 | 08:45 AM
mr sim's Avatar
Thanks for taking the time to replay
if the final drive is adjustable then how will i know i have a good final drive ready to tune individual gears Is there a standard number for drag racing to set final drive at
Also could you maybe show me an example of the calculations you do to find the top speed in every gear
Is the power curve the section after the hp crosses the torque line
Sorry for the amatuer questions
Old Oct 22, 2011 | 12:26 PM
xenocron's Avatar
http://www.teammfactory.com/gear-calculator
I've seen people setup elaborate excel sheets for their cars similarly
Old Oct 22, 2011 | 01:34 PM
mr sim's Avatar
215/60/15 front 305/14/15 rear
Power rpm 8500
Torque rpm4800
How do i figure out the best ratio for 1/4 or 1/2 mile from that calculator thing lol
Sorry for what probably are simple questions and i appreciate you helping bro
Old Oct 22, 2011 | 04:07 PM
Dynamic Performance Racing's Avatar
Go to americantorque.com!!! and clik calculation!!!
Old Oct 22, 2011 | 11:25 PM
Divers's Avatar
Choose a ratio that puts your rev limit at the top of 4th gear as you go through the traps. For example, a GSR that made 600hp revving to 9k would work great with a gsr tranny. 9k/1.034 4th/4.4FD x 6.41(24.5") x 60/5280 = 145mph. Perfect
Old Nov 22, 2011 | 12:41 PM
andelicek's Avatar
Have you seen this calculator?
http://www.cargister.com/calculator-gear
ecko_3420
11
Oct 20, 2012 09:28 AM
BeniRacing
Transmission & Drivetrain
61
Oct 25, 2008 04:37 PM
jt-sport
Aug 13, 2007 04:38 PM
nightryder21
May 20, 2003 08:04 AM
R2D2
Jun 17, 2002 07:40 AM
