Finally got 11's
Old Jun 21, 2005 | 08:12 AM
salt's Avatar
Default Finally got 11's
I'm still not getting enough practice to get some good 60 foots. So I just turned up the boost to make up for it. Thanks to hondaguyef for suggesting the 22" instead of the 24.5" I was using. I even hit 126mph before the rev limiter.
setup
gt30r @ 20psi
B18C stock sleeves with b16 tranny with quaife
2590 lb del sol with me in it.
I wanted to raise the boost, but my 680cc's@50psi were at 103%
Old Jun 21, 2005 | 08:27 AM
Finland's Avatar
Nice job Salt. You didn't just get 11s you got 11.8
That thing must be putting down some serious power.
Old Jun 21, 2005 | 08:32 AM
SPOOLED's Avatar
Default Re: Finally got 11's (salt)
damn man somethings wrong, 99 mph with a 7.9 e.t.
your MPH is good enough for at least some 7.3-4's!
Old Jun 21, 2005 | 08:47 AM
MartGSR's Avatar
Hey good job salt !
thanx for helping on aem ems forum.
Btw what is your rev limit ?
Old Jun 21, 2005 | 08:53 AM
11SEC CIV's Avatar
Default Re: Finally got 11's (MartGSR)
job well done , still looks like much room for improvement also
Old Jun 21, 2005 | 09:26 AM
salt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MartGSR &raquo;</TD></TR><TR><TD CLASS="quote">Hey good job salt !
Btw what is your rev limit ?</TD></TR></TABLE>
did you ever get your boost controller working ? mine is working great if you want a copy of my .cal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLED &raquo;</TD></TR><TR><TD CLASS="quote">damn man somethings wrong, 99 mph with a 7.9 e.t.
your MPH is good enough for at least some 7.3-4's!</TD></TR></TABLE>
I wish i could get 7.3 1/8 miles! I didn't get a burnout because this is a crappy track, and you have to back up to get in the water box, but if you have FWD you cant get back far enough to actually get some water, so I did a 2 sec dry burnout. on the launch my first gear grabbed pretty good, and second spun when i hit full boost. plus with everything happening I always forget to full throttle shift until the 3-4 shift
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">Nice job Salt. You didn't just get 11s you got 11.8
That thing must be putting down some serious power.</TD></TR></TABLE>
it feels fast, you just need a piston and rod upgrade and with a retune you should be about even with me!
Old Jun 21, 2005 | 09:34 AM
vtekthis's Avatar
what boost control u using?
Old Jun 21, 2005 | 09:47 AM
tthame1's Avatar
Default Re: Finally got 11's (vtekthis)
congrats on hitting 11's and insane trap speed.
Old Jun 21, 2005 | 12:55 PM
MartGSR's Avatar
Yeah now my boost is very constant ,and i have good control on it.
Vteckthis: Aem ems boost control with gm boost solenoid
Old Jun 21, 2005 | 01:12 PM
kazino42's Avatar
Welcome to the club. Just needed to get the power to the ground.
Old Jun 21, 2005 | 10:42 PM
Alstare's Avatar
Default Re: Finally got 11's (kazino42)
Good run...
Looks/sounds to be a Lapeer Dragway timeslip/setup...hah
Old Jun 21, 2005 | 10:47 PM
LurkerS8's Avatar
Thats awesome! My friend is trying to go with the same setup in a eg. I hope he gets pretty close to the same results you did.
Old Jun 21, 2005 | 11:44 PM
Rowdy's Avatar
Congrats on the 11's, almost looks like you are ready for taller slicks.
Old Jun 22, 2005 | 03:23 AM
hondaguyef's Avatar
Default Re: (Rowdy)
Congrats man!!!! Glad I could be of help. The 22's are the **** huh.......I told you . Your 1/8 is killing you though. On 11.80 runs my 1/8 is usually high 7.60's. Insane trap! That thing must have some serious top end cause you made up some ground on top half of the track. Welcome to the club
Phil
Old Jun 22, 2005 | 05:50 PM
mrbsponge's Avatar
good job bro, but yeah they are right, my traps were in the 7.30-7.40 with 1.6-60fts. but i had a smaller turbo, mine seemed to fall off on the big end, if you could get her out of the hole a bit kwiker she would be insane homey!
Old Jun 23, 2005 | 06:36 AM
seen4ever's Avatar
Default Re: (mrbsponge)
my 11.75 ran had me going 7.54 through the 1/8th.
more traction means much faster.
ProPerformance
May 9, 2007 01:37 AM
portenio78
Aug 10, 2006 11:09 PM
rayspeed
10
Aug 24, 2004 05:53 PM
racinskittle
Aug 4, 2004 09:15 PM
Racerage1
30
Feb 9, 2004 03:08 PM
