FIC or ID
Old 06-06-2012, 06:31 PM
  #26
Zer0_SpeedWorks's Avatar
Default Re: FIC or ID
Both are great.
But almost all our cars here runs FIC.
Old 06-06-2012, 06:53 PM
  #27
EJ1_Ex's Avatar
in my car I'm running 95 fuel pressure at 27lbs on ID1000s made 537whp and 392tq 5862
Old 06-06-2012, 09:49 PM
  #28
Brent L's Avatar
What do you guys like with methanol?
Prefferably m5?
Old 06-06-2012, 11:12 PM
  #29
v.i.gsr's Avatar
Originally Posted by 2k.civic.si
What kind of base pressures are you guys running on your fic or id's?
50psi base pressure.. On my FIC's..
Old 06-07-2012, 12:11 AM
  #30
uglyasscivic's Avatar
Good thread...
I have tuned a bunch of cars with ID and FIC. Both are perfect. We personally use, sell and I am sponsored by Fuel Injector Connection. I met these guys a couple years ago and have been extremely happy with them.
http://www.youtube.com/watch?v=13CGw...feature=relmfu
At the end of day there is more than one person in the world that can properly machine a injector just like there is more than one good engine machinist, tuner, engine builder etc.....
Old 06-07-2012, 06:09 AM
  #31
alpha's Avatar
I will continue to recommend and use Injector Dynamics.
Old 06-07-2012, 06:57 AM
  #32
2k.civic.si's Avatar
great info....anyone have input on how long they have been running their injectors for? what type of fuel? How much of a difference do you see when running a 16 volt system vs a 12 volt system? Have any of you managed to "lock up" the injectors using very high pressures?
Old 06-07-2012, 07:22 AM
  #33
Martian's Avatar
Looking for clarification
FIC as in Fuel injector clinic, or fuel injector connection? It seems both have been referenced in this thread.
Old 06-07-2012, 07:36 AM
  #34
gringotegra's Avatar
Pretty sure Fuel Injector Clinic is who most are talking about.
Old 06-07-2012, 08:39 AM
  #35
Dynamic Performance Racing's Avatar
Running 8x1100cc Fuel Injector Clinic since 2010 and thats when we ran our first 8 sec pass SFWD trim. We are still on the same injectors. Since tyen we had at least 150 passes since then.
We are running VP Import and 12v.
Old 06-07-2012, 08:58 AM
  #36
ShawnR's Avatar
We used id's on my green car with no problems, been using them on all our customers cars every since
Old 06-07-2012, 09:09 AM
  #37
CHEETAH's Avatar
ID1000 for me, all motor...
Old 06-07-2012, 10:30 AM
  #38
Turbogixxer's Avatar
The only problems I have had is that if let the injectors set in corrosive or hygroscopic fuel, it will give you issues (rust). Outside of that, I have put some pressure into them (both ID and Fuel injector clinic).
Old 06-07-2012, 10:48 AM
  #39
extralargenog's Avatar
2 years, 92 pump and C16
Old 06-07-2012, 11:52 AM
  #40
200 HP's Avatar
I have been running Fuel Injector Clinic 775cc injectors in my naturally aspirated K24 setup for the last two years without any complaint. I replaced my outdated RC 750cc injectors and the difference was immediately apparent; the idle was so much smoother and the car gained 7-10whp throughout the entire powerband.
In regards to fuel, I use E85 out of the pump.
Old 06-07-2012, 12:10 PM
  #41
solswap's Avatar
FIC 1100cc here. I have been using them for the last 2 race seasons with great success. My current setup is:
FIC 1100cc x 4
Weldon 2015 Fuel Pump
FTW Orange Fuel
16v Lithium Battery
140psi base pressure
As you can see I am running some serious fuel pressure. I have not had any issues with the injectors "locking up." I would highly recommend these injectors to anyone.
Old 06-07-2012, 12:24 PM
  #42
JdM iGeN's Avatar
FIC 2150cc
Old 06-07-2012, 12:52 PM
  #43
4cylfiend's Avatar
I have never ran an injector besides an ID injector so I cant say anything about other brands. My ID1000's were awesome but when I ran out of fuel I bumped up to the ID2000's. Both sets were very consistant and the engine idled like a dream.
Old 06-07-2012, 06:47 PM
  #44
Anyone have any examples of testing back to back id vs fic showing any power gains on the dyno?
Or possible id or fic vs another brand like rc?
Old 06-07-2012, 07:14 PM
  #45
mtber's Avatar
T1 did a comparison vs stock injectors a while back..
http://www.youtube.com/watch?v=RX1xIvOWcNk
Old 06-07-2012, 07:21 PM
  #46
dankeg's Avatar
They wont be any power gain's between FIC and ID or any of those company's that use that style Bosch injector
Old 06-07-2012, 07:48 PM
  #47
Divers's Avatar
Originally Posted by jdm inc
x2 been on id 1ks on q16 for about 3 season! switching to id 2ks soon!
ID injectors ftw!
Switch fuel too then.
Old 06-07-2012, 08:34 PM
  #48
fo0
fo0's Avatar
i think they are the same injector, FIC and ID, they get them from the same place BOSCH but the ID's are flow tested in large batches and are matched up in groups that have the same flow rates unlike the FIC's.
that's what I've gathered
Old 06-07-2012, 08:47 PM
  #49
E Town DSM's Avatar
Niether actually make the injector. They do modify\flow\match them in their own way which is what makes the difference.Tuners usually dont make the engine managment but it still matters who tunes it right. They will both get the job done for the most part its the little driveability stuff and idle quality that is the big difference. I run id's without any complaints even with running them on Import which they arent even meant for.Still work flawlessly.ID's are my choice
Old 06-08-2012, 06:03 AM
  #50
Fuel Injector Clinic gets thousands of them at a time and flows them in larger batches to match them better. I have watched them do it and have seen boxes and boxes of the same injector size.
You can see the difference when people do not flow them in larger groups. There is plenty of much cheaper injector companies that do not flow or do not flow them in batches.
Quick Reply: FIC or ID
