Feb FS Thread
I have three Burns Stainless 304SS collectors to build a custom 4-2-1 header. The basic run down is 1.625" primary, 1.750" secondary, and the choke transitions to a 2.5" outlet. I have a build sheet which details lengths based on roughly 2.1 engine displacement with a head flowing 240+ cfm. These were to be used for a Volkswagen but should work well for most B and H series engines.
I cannot post pics here for some reason, here's a link: http://forum.vwsport.com/pics/showgallery.php?cat=3194
I've got $475 wrapped up in them; all items are brand new, make an offer... thanks.
K Series Magnus Intake - $650+fees Shipped obo...
Used for 800 miles, port matched to the 74mm tb but willing to sell separately, runners have also been welded for reinforcement.
S90 74mm K series Throttle Body (no map sensor) - $175+fees Shipped
KTuned Pro1000 Fuel Rail- $130+fees Shipped
Fuel rail has never been in use.
K Series DW BNIB E85 Safe intank fuel pump - $120+fees Shipped
The Intank pump comes with all wiring necessary for install. Never taken out of sealed plastic.
Contact: Email: toughk20@gmail.com
Text: 202-714-5076
Text: 202-714-5076
selling my SFWD integra RS shell that I purchase from a fellow HT member...this car is ready to go just needs a swap and ur good....car was previously featured in Tunerzine magazine ...this car was since repainted with PPG super sonic gsr blue and fitted with a JDM exospeed wide body front..also has a certified mazworx cage/window net etc .2 kirkey seats.stroud parachute.brake booster delete master cylinder,shaved bay.skunk2 Pro c suspension with custom spring rates, full-race traction bars with custom front tubular frame front to assist the wide body and 60pounds on the nose of the car. custom catch pan for underneath the motor, DSS 5.9 hubs, ARP wheel studs all around an skunk2 lug nuts , slotted rotors and pads.really hate to get rid of it but not practical for me to build at the moment..price is $7000....if interested u can reach me at 305 281 6495 ryan...
http://www.tunerzine.com/view-articl...ce-dc2-feature
also selling the welds 2.0 magnums rears for $1200 with tires and
weld fronts 13x10 for $800 with slicks...both have literally 4 passes down the track so there pretty much new still
B16A head ready to run fresh from the machine shop. Set up for nonvtec block, stock valves, Crower retainers (could have Crower spring but not 100% sure)I received it as you see it. New valve job and resurfaced $600 shipped
B20Z Block has matching mains, no cracks. Will ship at buys expense $100
AEM cam gears B-series $100 shipped
Quaife LSD for B16/LS $600 Shipped
60mm Tial wastegate needs diagram SOLD
Weldon 2015a fuel pump used for 5 passes $375 shipped Sale pending
DC EG/DC2 rear lower bar $50 shipped
Mugen rear upper strut brace (REAL no fake ****... I bought it from Kings Motorsports 10 years ago) $180 Shipped
stand alone custom engine harness just add power and ground.
setup for 8 side by side injectors id2000/1000 clips k series coils AEM EPM
includes AEM 1010 box AEM EPM j32 coils that fit under cover bad *** 50$ relay that powers ecu/coils.
all for $700 shipped everything works fine.
Complete engine/turbo/trans setup built and always maintained by my sponsor, Full Blown Motorsports. Everything still in the car as it sits, and will be disassembled in the next few days. Got another ride to focus on for 2014, so this combo needs a good home. Car made 713hp/465tq at 35psi/E85.
Block: (Built April 2013) Bensons sleeved B18B1, 81.5 Arias Pistons w/upgraded wrist pins, 7/16 Eagle rods, ACL bearings. $2600
Head: GSR head, full B.R.E. Ported. Ferrea inconel valves, springs, retainers (no valve cover, dist. or vtec solenoid) $1400
*Valve cover is not for sale*
Buy complete (still) assembled longblock and get oem HG, GE studs, and Gates Belt included.
Tranny: GSR gearset with LS FD, RacerSteve heat treated gears. Wavetrac lsd, Syncrotech carbon syncros. Speed Factory shift change assembly (Built 9/12) Still shifts like the day the shop built it. $1700
Shift linkage with ES bushings and universal joint by RC Autoworks. ES bushing at stabilizer/trans is torn. $150
Turbo Setup
Short ram, DP, dump made by MDG fab. (Wastegate not included)
Precision 62/66 journal (fresh back from rebuild by Precision)
FBM 750hp intercooler with aluminum piping, Blitz bov, couplers, and clamps. $1700
Complete Fuel system FBM dual pump hanger with (2) FBM 340lph pumps. -6 feed and return with AN fittings to FBM rail w/FBM fpr. $650
Misc:
Exedy Twin disc $1000
Edelbrock VictorX Gsr w/Hondata heat gasket $300
70mm FBM throttle body $90
Tial 38mm wastegate w/15psi spring **SOLD**
Avid B series mounts $220
ATI street dampner $300
Catch Can setup w/AN hoses $200
Hondata S300 with BBG and boost solenoid **SOLD**
Omni 4 bar map sensor $75
Custom engine bay harness built by Vtecnician $150
Lenso fronts w/24.5/8.5/13 MH slicks (35% left) $500
Sheepey Spec Web cams. $550
Avid Traction bar $275
Z series mechanical boost and oil pressure guages, with stainless oil line. $125
GE oil sandwich $75
Vband 3" exhaust (Everything after downpipe for EG hatch. 18" resonator. System has no muffler. $300
GE headstuds $90
Skunk2 Pro Series cam gears $200
B series axles, Napa (not remans) $120/both sides
Picture taken today
Last showing of 2013 before being stored at the shop.
When the engine was assembled for the 2013 season: 04/23/13
Turbo fresh from Precision
Lenso Fronts
Fuel Pumps
Gauges
Steve@Paintmode.com is the email for all serious inquiries. Well documented build over the years.
Turbo Setup
Misc:
GE oil sandwich $75
GE headstuds $90
Picture taken today
Lenso Fronts
Fuel Pumps
Gauges
For Sale:
Skunk2 Ultra STREET intake manifold. Never been installed on an engine. All parts are with it. $350
Skunk2 Pro Series intake manifold. Used, fits a GS-R. Works great and no cracks or problems. $150
Eagle H Beam rods, used in a GS-R. No issues and in great condition. Pulled with 1500 miles on them. $250
No Name or OBX helical LSD. Never installed and bought for a b16 tranny. $275
Stealth 340 LPH pump, NIB. Has everything to install into a fuel tank. $125
Set of 4 ID1000 Injector Dynamic injectors. Never used and still in original package. All plugs come with them to make your own connectors. $435
All PayPal fees and shipping will be paid by the buyer.
Skunk2 Ultra Manifold
Skunk2 Pro Manifold
Eagle H Beam GS-R rods
OBX or No Name Helical Diff
Stealth Fuel Pump 340 LPH
ID1000 Injectors and clips
Skunk2 Pro Manifold
Full b series turbo kit. All you will need is a blow off valve. Borg warner s366xl T4 1.1. Turbo comes with the coupler and -10 drain. Couple hundred street miles and a few dozen track passes on the turbo and manifold. Brand edelbrock victorx which I had powder coated. Top mount manifold 46mm vband wg flange. Precision 46mm wastegate and dump tube. I have the box and everything it came with. 4" up pipe ceramic coated. Blox 72mm billet aluminum throttle body. 3" polished intercooler piping with vanjen clamp on throttle body. Precision 800hp core with back door on inlet side. Comes with carbon fiber hood that's already cut out for the up pipe. $3500.00. I just had the intercooler, intercooler piping and up pipe fabbed up. Its brand new. Going with a forward facing setup, that's the reason for selling. Came off of a eg hatch chassis. $3500.00 obo
MSD vtec wire $35 shipped.
-10 catch can lines. Theres enough slack to use these on the back of the block or intake manifold side of valve cover if your can is where the battery use to be. $45 shipped.
