Feb 2011 FS Thread
Old Feb 11, 2011 | 09:19 AM
  #76
Mr. Em1's Avatar
Default Re: Feb 2011 FS Thread
Well I have decided that my priorities are changing and as close as it is to being done and everything I need to put my money elsewhere, so I'm getting rid of everything.
email = Sjlutwyche@hotmail.com
phone = 914 382 4163
Almost all Parts are brand new and Only have minimal Dyno Time
All Parts are from a 1999 Civic si
This is quickly off the top of my Head I will add prices later and finish updating later
Turbo Kit $3500
Manifold,Downpipe,Dumptube $800
Custom Inline Pro Manifold T4/60mm $500
4 Inch Downpipe to 5 Inch muffler(exit under halfway near shift linkage) $300
Tial 60mm Wastegate $500
Borg Warner s368 .96 Hot side 1.10 Cold Side $1200
2.5" Dumptube $100
T1 1000hp Backdoor Intercooler (V Band Passenger Side) $1000
3" Aluminum Intercooler Piping w/ Tial 50mm Blow Off Valve $300
Motor 3000 obo
Block
85x87.2 Dart standard deck
8.7:1 Ross Pistons
Oem Gsr Crankshaft
Eagle H Beam Rods
Arp 2000 Rod Bolts
Arp Main Studs
Arp Flywheel bolts
Arp Pressure Plate bolts
Arp Head Studs
Type r water pump
Type r oil pump with Prodrive oil pump gears
Moroso 5qt oil pan with gsr pickup
Cometic Headgasket
Acl Rod and Main Bearings
Fluidamp Race Version $250
1100
1989 B16 head Stock Port, Stock Lmas etc
Ferrea Valves, Springs, Keepers, Retainers, Lockers
Skunk 2 Covered Vtec solenoid $80
Fuel System 700 for everything This includes all the -10 lines, -6 lines from the tank to your fuel rail,all the fittings neccessary for your fuel rail(golden eagle) the full blown Kit with the 2 Walbro's and the necessary wiring for the pumps with
MORE detailed pictures to come SOON!
Black Nylon Hose, Mr Gasket Fittings 300
-10 Feed
-6 Return
Full Blown Dual Walbro Setup W/2 Brand new walbro 255lphs all connected and working flawlessly $450 FIRM
Electronics
Custom Chasebay's Milspec Connector Harness w/ FJO Injector $1000 Firm
Msd Pro Cap on Oem b16 Distributor $150
Msd Digital 6 ignition Box $200
Msd hvc 2 Coil $100
obd2b-obd1 Jumper Harness $50
Misc
Vision Hood Props $120
Vibrant Extra Tensioner - $150
Mishimoto Rad Hoses b16 $50
Spoon Carbon Kevlar Spark Plug Cover - $120 FIRM
Gforce 5 point cam lock Harness - $150 FIRM
Dss 5.9 - 1000 for axles 1400 for axles with my knuckles with the spindles and extended studs(new lower Ball Joints and Wheel Bearings) or 1200 And you trade me your Knuckles
Full Race Pro Am Traction Bar - $300 FIRM
Gsr Transmission 75k NO ISSUES $600 w/oem diff
Mfactory Plate Lsd $700
Transmission with LSD $1100
BRAND NEW Competition Clutch Twin Disc $900
Omni Power 12k 18k Full Drag $800 FIRM
Hasport Steel Mounts(driver Mount 60a Rubber, Trans and Rear Full Steel) $275
Old Feb 11, 2011 | 11:52 AM
  #77
Hondoctors's Avatar
Default Spearco Air-Water Intercooler Kit
This is a Spearco Air-to-Water Intercooler kit. The intercooler has 2.5" pipe openings, comes with 3-gallon water tank, Shureflo water pump. This kit was on my Acura Integra Race Car and made over 600 HP to the wheels. Comes with everything pictured.
$550 shipped to lower 48 states.
Old Feb 11, 2011 | 11:58 AM
  #78
Hondoctors's Avatar
Default 1996 Acura integra 4-door
I've got a 1996 Integra GSR 4 door for sale. It has a Rebuilt Title (was a theft recovery that was rebuilt at Hondoctors, never crashed)
This Car Does Have: Fluidyne Aluminum Race Radiator, VIS Carbon Fiber Hood with Hood Pins, Hondoctors Custom Drag Race Traction Bar, 6-point roll bar, Autometer 3-gauge pillar pod, Full Interior as shown in pics, OBD1 under dash wiring conversion, Stock suspension and springs
This car has: No engine, No transmission, No gas tank, No fuel lines, No exhaust, No wheels (you must provide a set of wheels)
This car is a retired 10-second drag car, it has never been in an accident, no body damage
This car is sold As-Is
$1600
Old Feb 12, 2011 | 05:33 AM
  #79
TopEndUSA's Avatar
SOLD
Old Feb 12, 2011 | 09:27 AM
  #80
dow3rk's Avatar
Would anybody be interested in a ProLogger? Previous owner used it for 1500-2000miles.
My car hasn't ran in over a year and I never used it. Since I have wideband logging and boost control I think Im going to part with this.
450 shipped. Comes with the harness, wideband sensor, relay, and the boost solenoid.
PM for info!
Old Feb 12, 2011 | 10:08 PM
  #81
Lightspeed41510's Avatar
I have a used MSD DIS 4 box (old style with dip switches) and a set of 4 (not assembled) coil wires for a k series individual blaster coil setup.
I am selling the box for $180
Coil wires with all parts needed to complete a set of 4 wires: $80
Email skippworks@gmail.com
Old Feb 13, 2011 | 06:41 AM
  #82
alopez84's Avatar
Brand New H22 SPEC Twin Disc clutch $975.00 shipped
Old Feb 14, 2011 | 06:57 AM
  #83
Dynamic Performance Racing's Avatar
Hondata S300 Chipped in a P28. Also includes Hondata's 4 Bar MAP and Boost By Gear Option. Already has a base map for 1600cc injectors so you can drive your car to your tuner. SOLD
75mm Edelbrock Throttle Body. Includes 2 Gaskets and a universal plate. SOLD
Please call me at the shop at 908-393-5086 or PM me here.
Thanks,
Rolando
Last edited by Dynamic Performance Racing; Feb 15, 2011 at 06:00 PM. Reason: Sold Edebrock throttle body and S300
Old Feb 14, 2011 | 01:01 PM
  #84
94 ls teg's Avatar
sold
Old Feb 14, 2011 | 05:09 PM
  #85
acrite1999's Avatar
sold
Old Feb 14, 2011 | 08:29 PM
  #86
therunnerz's Avatar
ID1000s for sale $375 perfect condition
front 13inch lenso gold wheels (no slicks) $300
Rear 15inch gold lenso with tires 90% thread $500
text me for quick response 214-576-6367
Old Feb 15, 2011 | 11:28 AM
  #87
DSRxCandyh2bEG's Avatar
Default FS: DTR/SSR h2b stainless steel Tri-Y Race Header
**************SOLD***********
I have a h2b DTR/SSR stainless steel Tri-Y Race Header with megaphone for sale.
I have made 296hp/201trq with this header and it has the ability to support more.
asking $1050 obo
Side note: The header has excellent ground clearance... hint hint for you evolution kit owners...
Old Feb 15, 2011 | 06:44 PM
  #88
Stealthmode Performance's Avatar
Skunk2 intake manifold for GSR. Matched for 70mm TB. $175 shipped.
Old Feb 16, 2011 | 12:54 PM
  #89
BILLY_BAD_A$$'s Avatar
K20 head $1400(head is pretty much ruined unless you want to weld and mill it)
supertech full valvetrain. Stainless Nitride coated intake valves. Inconel exhaust valves. All standard size. Seats from supertech as well. Ep3 cut rockers for single lobe. Drag Cartel drop in cams cut to single lobe.
Exospeed Front Rims 13x9 5" Backspacing $900
K series intake manifold $450
K series Peak boost side winder. Dual 44s and t4 divided $800
Hybrid K series Solid Mounts for EK brand new $500
K24 crank $200
Old Feb 16, 2011 | 02:55 PM
  #90
gizzmo222's Avatar
Stock Sleeve LS/VTEC Long Block FS:
Head: GSR
-Gasket Matched Port & Polished
-InlinePRO Valve Springs
-Stock Retainers
-Stock Honda Valves
-New Honda Top End gasket set
-ARP Head studs
-Cometic Head Gasket
-OEM ITR cams/stock cam gears
Block: B18A1
-Stock Sleeves bored .20 over (81.5mm)
-CP Pistons 9.0:1 compression ratio
-Eagle H-Beam Rods
-ARP Rod Bolts
-Polished crank
-ACL Rod/Main bearings
Motor was ran for 3 years and has under 2,000 miles on it. It was PROFESSIONALLY built by a machinest. From start up the motor was ran with AMS Oil 5w-40 and is changed everytime after the track. Only 1,500 road miles on her. Doesn't smoke one bit, no valve lash or anthing. Still in great running condition, I don't sell garbage parts. Some people know my name and I don't want to ruin my image at the track so help a fellow racer out and please buy this motor!
Looking for $2,200 OBO for the long block minus the intake manifold.
PM me for more information, thank you.
Old Feb 17, 2011 | 10:08 AM
  #91
Antilag's Avatar
Obd2 dizzy freshly rewired, only missing is the part that goes into the head, i had to use that for me aem epm. comes with distributor cap. 70.00
obd 2 alternator great condition B-series, i upgraded to a 170amp, this thing has 20 miles on it. 50.00
Mfactory cam gears red B-series. Awesome vernier adjustables. mint! 75.00
Bilge 3700 gph water pump. unopened in the box. Awesome monster pump for a liquid to air setup. 90.00.
These prices does not include shipping or paypal fees.
If you want pictures, please im me with your email address.
Old Feb 17, 2011 | 01:50 PM
  #92
I.C.C.'s Avatar
-Autometer Phantom boost gauge (pt# 5703) reads 30in Hg to 30psi of boost. Gauge is used, but in great condition, AND I will include all new light, fittings, tubing, etc. $40 OBO
-FullBlown Motorsports dual Walbro pump hanger for 92-00 Civics and 94-01 Integras. Includes both fuel pumps and aluminum -10AN feed and -8AN return fittings (no lines)... Great for making a ton of power without sumping your tank... $450 OBO
-Turbosmart dual stage manual boost controller...Practically brand new. Was installed on a car, but pulled off almost imediately in favor of an EBC.. $150 OBO
-OBD1 BSeries lower timing cover Good condition... $40 OBO
-BBK 70mm Throttle Body w/ TPS sensor. Throttle body flange was cut to weld on a v-band style flange, but ended up going another route... Still in perfect workin order, just needs a flange welded on... $140 OBO
-OEM Honda Injector resistor box $30 OBO
-Hayden/Imperial 10" slim electric reversible (push/pull) fan. Flows 650cfm. Brand new in box... Bought 2 of these for my car, but found 1 to work perfectly fine so this one has just been sitting in the box for a while... $60 OBO
-Stock GSR pistons and rods. Great condition! $120 OBO
-EG/DC B Series T-Bracket... $60 OBO
-B-Series crank pulley (GSR) in excellent condition. No chips! $40 OBO
-EK clutch hardline brand new in package from Honda $50 OBO
- -6AN steel braided lines/fittings to connect factory fuel filter, to aftermarket fuel rail. $20 OBO
-B Series front trans. mount WITH torque mount AND AC compressor bracket WITH torque mount. Both torque mounts have Prothane inserts. $60 OBO
-Lenso VPD drag wheels with M&H Racemaster 25x8.7/13 slicks. Wheels are GOLD in color, and in perfect condition, and tires only have about 6-8 passes on them. $550 I'm pretty firm at $550 with these, but money talks.
- BRAND NEW steel -10AN weld on bung. Perfect for tapping an oil pan for turbo oil return. $10 OBO
All prices are OBO ... Shipping costs are extra, to be paid by buyer. Pictures are available upon request...
If you are interested in anything or have any questions, please PM me, or email me at BoostedCivicSedan@yahoo.com
Thanks,
Chris
Old Feb 18, 2011 | 06:48 AM
  #93
s2kfromhell's Avatar
Pretty-n-Pink
I'm selling a used AEM 1052 Box for the s2k for 900 shipped and two bosch 044 pumps that are brand new for 175 a piece shipped.
Old Feb 18, 2011 | 08:25 AM
  #94
habib's Avatar
sold
Old Feb 18, 2011 | 12:11 PM
  #95
vtekthis's Avatar
Brand new 85mm JE pistons, with thicker upper ring lands, and the thickest wristpin JE makes. 10.0 comp flat top, same pistons used by the guys making 1k plus HP on here.
550 takes them.
Old Feb 19, 2011 | 06:40 AM
  #96
turbo-2nr's Avatar
for all you weird sohc guys!!
EnDyn built SOHC head
port and polished
supertech valves
dual springs
retainers
seals etc..
new never used!!!
$800
Old Feb 20, 2011 | 08:28 AM
  #97
vtec_killer_'s Avatar
Testing waters to sell whole car first.. Aint got no time for BS scammers or door kickers.
Ran out of money to complete car, everything brand new. Please PM your phone number.. Here is a video of the car when it was all motor.
11.2 1/4 mile 260hp all motor: http://www.youtube.com/watch?v=ROm9A5H2PUY
1993 honda civic hatchback..(clean title)
brand new paint and lexan windows
Roll caged
Lenzo vpd wheels with 24.5 x 9 and skinnies
1 peice front end
traction bars up front
suspension:
Illumina shock with skunk2 coilovers
skunk2 rear lower arms.
carbon fiber floors in rear
welded points for wheelie (traction bars) also included
brand new kirkey seat
NRG quick release with MOMO steering wheel
Custom dash with all accessories for shutoff and on..
autometer gauges installed where cluster usually goes..
Hasport motor mounts
aeromotive fuel pump and -an lines
MOTOR:::::
H22 custom build motor
Golden eagle manifold
golden eagle fuel rail
skunk2 70mm throttlebody with 4 bar map sensor
aeromotive fuel pressure reg
BoB Mckray ported and polished head
ferrea valves and springs retainers
JE custom 9.5.1 dish pistons
Custom H-beam rods
Darton sleeved block
custom belt pulleys
motor blueprinted and balance by CLU
clevite bearings
Drive oil pump
3 sets of axles (hasport, custom, Driveshop)
hyper stage 6 clutch
heavy duty pressure plate
fidanza enlighten flywheel
Scatter shield
brand new starter, alternator
Turbo system not complete yet:::
brand new never ran Synapse turbo manifold t3/t4
brand new precision t3/t4 turbo 6765 billet wheel h cover
hondata s300 with boost by gear
innovative lm-1 wideband
tial 44 wastegate
1680 cc injectors (bosch)
moroso oil pan
(will also throw in extra k20a3 complete longblock and b16 head and any other honda parts i have
i want it all gone.
Everything for 10k
will seperate if condition are right.
Old Feb 20, 2011 | 11:48 AM
  #98
Desir Performance's Avatar
Got for sale brand new in the box parts. Prices are best offer and buyer pays shipping.
Weld Racing Wheel, Magnum Drag 2.0, Aluminum, Gold, 15 in. x 3.5 in., Spindle Mount, 1.75 in. Backspace $950 pair
Kens Kustom Chassi stright axel, this is a direct bolt on for 92-00 civic or 94-00 integ. The axel comes with drilled rotors and 2 pistons brakes. it shaves 80lbs of your car. $1600
can cut a deal if the wheels and Axel is bought together (buyer pick up or pay for shipping no matter what)
Percy's racing lexan window kit for 96-00 honda civic hatch. this is the deluxe model that has the borders around the window for the stock look. this is a pnp kit no cutting needed, comes with all hardware and gasket for install $1200
Rci Fuel Cell, Drag Race Cell; Size 6 x 6 x 12; 1 Gallon $70
Waterman racing in-line fuel filters got 9 of them 5 -8 filters and 4 -6 filters $65 each
Fidanza racing light weight flywheel for b motor $80
gm 3bar map $40
M&H 28x10.5x15 drag slicks never mounted $350
M&H 26x4.5x15 drag skinnys never mounted $240
open to trades.
Old Feb 20, 2011 | 03:44 PM
  #99
boostedeg's Avatar
Full race ramhorn T3 turbo manifold - $590 obo
Full race 3" downpipe slight dent but flows fine O2 sensor not included - $200 obo
Tial 44mm wastegate w/dumptube - $285 obo
Precision 825 hp intercooler brand new in box - $495 obo
AEBS intake manifold fits b16 and itr heads slightly used(dyno time only)w/honda intake manifold gasket & honda tb gasket - SOLD!!!
Inline Pro T4 cast iron turbo manifold brand new (not pictured) - $400 obo
Custom 3" exhaust system w/borla muffler (not pictured) - $300 pick up only
Tial BOV brand new in box (purple) (not pictured)- $200 or obo
Any questions email me @ boostedeg@yahoo.com or PM me.
Old Feb 22, 2011 | 01:34 PM
  #100
b00stin93's Avatar
Full Race topmount manifold T3 flanged - $900
Garrett T3/T04E 57 trim .63 turbine housing w/ polished compressor housing-$450
RC 550cc injectors-$180 shipped
Tial 46mm Wastegate and dump-$300
Competition Clutch Stage 5 clutch-$200
CC Ultra lightweight flywheel-$125
GM 3bar map sensor-$50
All parts have about 5,000 Daily miles on them and 4 track days minus the clutch which is about 1,000 miles.
Made 412 with this turbo and manifold on 15psi on a bone stock GSR.
prices do not included shipping
