faster to shift slower?
Old Feb 15, 2004 | 09:59 PM
lke2drvgsr's Avatar
Default faster to shift slower?
is it faster to shift slower (~1 second to shift) vs. going right to the next gear in a split second? a friend of mine says that, he made a vid going up to 115 mph and shifts ridiculously slow... and i shift pretty damn quick (koalayummies can vouch ) anyway, i was wondering what's quickest and why?
here's the movie: (right click, save as)
http://www.we-todd-did-racing....DE%3D
Old Feb 15, 2004 | 10:13 PM
ModenaTwinTurbo's Avatar
Default Re: faster to shift slower? (lke2drvgsr)
generaly slow shifting will give you both higher trap speeds along with a higher time
and faster shifts will give you lower trap speeds (cuz the car didnt have enough time to accelerate to a higher speed) and a lower E.T
Old Feb 15, 2004 | 10:20 PM
lke2drvgsr's Avatar
Default Re: faster to shift slower? (ModenaTwinTurbo)
ok but exactly why is it quicker?
Old Feb 16, 2004 | 10:08 AM
the jdmchop's Avatar
shifting slower gets you higher mph and ET
quick shifting gets u lower mph and lower ET cuz your shifting faster
basicly shifter slower gives u more time to get up to speeed but by doing that it takes time away from your ET
Old Feb 16, 2004 | 11:20 AM
lke2drvgsr's Avatar
Default Re: faster to shift slower? (jdmchop)
how does it get your trap speed higher? i just dont get it
Old Feb 16, 2004 | 11:36 AM
why does it even matter?
moral of the story is dont sit there granny shifting , rip thru those gears!!!!!!
Old Feb 16, 2004 | 11:41 AM
lke2drvgsr's Avatar
lol i like knowing WHY
Old Feb 16, 2004 | 11:50 AM
Suprdave's Avatar
The slower you shift the more time that zero power is going to the wheels...how could that be better in any circumstance?
Old Feb 16, 2004 | 12:00 PM
lke2drvgsr's Avatar
Default Re: faster to shift slower? (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">The slower you shift the more time that zero power is going to the wheels...how could that be better in any circumstance?</TD></TR></TABLE>
exactly what i was thinking, can someone tell me why zero power=higher trap, but lower ET?
Old Feb 16, 2004 | 12:14 PM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lke2drvgsr &raquo;</TD></TR><TR><TD CLASS="quote">
exactly what i was thinking, can someone tell me why zero power=higher trap, but lower ET?</TD></TR></TABLE>
It doesn't...shifting slower does absolutely nothing for you...
Old Feb 16, 2004 | 12:16 PM
lke2drvgsr's Avatar
suprdave, i think im ready to get that dyno done i know its been so long, i just have been really short on cash and couldnt afford the tuning and the ecu chip, but im finally scrounging enough money, and wondering when i can come in to get my car tuned? the problem is that on the compression test, my cylinders were all 170 psi with 10% leakdown... i SHOULD be up in the 240+ psi range on my setup, and i'm wondering if my numbers are off because of bad cam timing or something since the leakdown test shows minimal leakage.
Old Feb 16, 2004 | 12:24 PM
lke2drvgsr's Avatar
The second bad habit some people have is shifting with excessive force. Too tight a grip, and slamming from one gear to another will actually slow your shifting down, and cause excessive mechanical wear. Proper shifting uses an open palm grip on the top of the shift ****, and a gentle but fast guide from one gear to another. We repeat---all shifting is properly done with the hand open and cupped over the top of the ****, not wrapped around it like a fighter plane control stick.
this is what he sent me explaining this topic, but it really doesn't say anything at all theres no reasons explaining anything other than how to hold a shiftknob
Old Feb 16, 2004 | 04:52 PM
96dc2's Avatar
Shifting and working the clutch go hand in hand. So don't forget your footwork.
Old Feb 17, 2004 | 05:46 PM
Boltz's Avatar
Default Re: faster to shift slower? (96dc2)
You do shift SLOWER for FASTER times... thats retarded.
If you shift TOO FAST, and then try shifting SLOWER, you should see better times.
The fastest "shifting" will always net you the quickest times, BUT <U>if when</U> you shift you re-engage the clutch either too fast or with too much throttle with not enough traction, you will start spinning the wheels again. Which obviously wont help when 1/10th of a second later you are flooring it.
Old Feb 17, 2004 | 09:10 PM
Vtexivic's Avatar
thats werid how that works
Old Feb 23, 2004 | 05:31 PM
SOHC Gord's Avatar
try it at the track and see witch works better for you
Old Feb 24, 2004 | 06:06 AM
JBBNJ609's Avatar
Default Re: faster to shift slower? (SOHC Gord)
wow that vid was just bad , he really shifts like that all the time?
Old Feb 24, 2004 | 08:58 AM
lke2drvgsr's Avatar
Default Re: faster to shift slower? (jason bouchard)
heh apparently it was some other random video, that wasnt my friend, me and him had some miscommunication about it but ya, that's how he thinks shifting should be when racing....
Old Feb 24, 2004 | 03:10 PM
yaya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lke2drvgsr &raquo;</TD></TR><TR><TD CLASS="quote">lol i like knowing WHY</TD></TR></TABLE>
when you shift really fast you will break loose.....if you take an extra .2 sec to shift you can release the clutch slower and you tires wont spin as much going through your gears
Old Feb 24, 2004 | 04:44 PM
lke2drvgsr's Avatar
Default Re: faster to shift slower? (YAYA!)
with good tires i don't break loose so is that the only reason?
Old Feb 24, 2004 | 05:36 PM
yaya's Avatar
if your tires dont break loose ever.....shift as fast as you can while keeping your revs up wehre they should be
in my small amount of exp in drag racing. if i shift as fast as i can, i break loose in 2nd so bad its actually funny.....i get better times if i let the clutch out a tad bit slower. but like you said, you dont break loose....so shift away
needaimport
Feb 3, 2005 08:28 PM
proton
Jul 9, 2002 02:59 PM
pub
Jun 27, 2002 10:43 PM
CivicGSRTurbo
May 31, 2002 05:22 PM
