Exhaust back pressure....
#51
Re: Exhaust back pressure....
3 psi diff huh? at 280 kpa id be more worried about being 8 psi above map honestly...
Joe, are u using 2 T1 dampers on each signal? you said duel damper kitm im curious how u have it set up o be unbiased
#52
HELLO,GOOD MORNIN'
i understand what your saying, but there is still a difference, when technically it should be the same. if you have two gates both at 9psi springs, why is there a diff from one side to the other?
the 8psi back pressure diff is still pretty close. to 1:1. not too far off
#54
saying that a 3 psi split is not acceptable is NOT ok, but 8 psi above map is close enough.....that **** is funny.
Tony- yes you did at one time until u found out how bad it was lol why not show ur most recent I2 data lol
#57
have you guys tried bridging the actual runners to the gates in stead of the turbo? I think that might help equalize the pressure between the gates?
#58
Are u guys testing to make sure all the sensors read the same I would see a few psi swing from different sensors the 5 bar and the 0/100 psi sensors never matched and evan the same manufactures sensors would be off a little bit a wrote a math channel in the aem and used shop air to get them all withen a half a psi of each other still had problems getting the twin gates to match whent to a big single problem solved
#59
It's not a sensor cal issue, the problem gets worse as EMAP increases because the gates are closing. Equalizing pressure solved the problem, which wouldn't be the case if it was a sensor cal issue.
#60
Vtekthis, sorry, I had the math scalar set up wrong for the map, lol. I had a -14.7 in the offset for the map display, whoops! See what happens when you go changing it from kpa to show it?
Manifold pressure was actually 5-6 psi higher than emap..
#61
so u scaled the map but not the emaps? i had to train myself KPA just to play with the Motec, or else i just confusd myself over and over again lol
#62
Joe, i'll send you some info on how to make math channels to have PSI versions to pull up with having to offset them for atmosphere.
#63
Yep, lol. Just switched laptops and didnt have my normal layout settings.. I almost need a cheat sheet taped to the side of the laptop for kpa-psi and C to F, lol.
#65
#66
Still not a bad idea to check all the sensors from a single source to give u a base line
#67
Very possible and something I considered as well, but seeing how much a very small percentage of wastegate opening can make on things I think it's more likely to be a gate issue.
In any sense, even if everything is perfect, it's only like that till a gate starts acting up.
#68
#70
I don't run a honda...
new setup should be ready sometime next year...
thought this topic was about backpressure not ET's or MPH...
#72
Thanks guys for all the technical discussion on this topic. For those of you contemplating or have already done so, gone to a single gate, are you still running a divided collector? I am possibly looking at building a new manifold and am stuck on the decision of a single gate and divided vs. non-divided collector. This will be for a divided turbo.
#73
IMO what does any of it matter? If it doesnt have result in ether MPH, ET, control, or reliability. I have never checked BP and wanted to know if its relevent. Yes theres a difference in the gates. I want to know if theres is gains of any kind by equalizing them.
#74
I know what you have. I wanted to know if you had results.
