egt temps
Old Apr 10, 2011 | 06:03 PM
boostaout's Avatar
Default egt temps
I HAVE A AEM EGT SETUP IM LOOKING TO GET INFO
ON WHAT IS A COMFORTABLE EGT TEMP.......... IS THERE
A CETAIN TEMP I SHOULDNT GO PASS?
81.5MM, 11:1CP TURBO MOTOR ANY INFO
WOULD BE GREAT IM NEW TO THE WHOLE EGT THING
Old Apr 10, 2011 | 06:46 PM
LightningTeg's Avatar
Community Builder
Default Re: egt temps
NICEEE DAWG
Old Apr 10, 2011 | 09:17 PM
cibao2ner's Avatar
do you have the 4 egts? how is it? all i know is the hotter the leaner....no more than 1500f
Old Apr 11, 2011 | 05:38 AM
boostaout's Avatar
Yea I have 4 egt's, but yet to make use of them just info first on some temps
Old Apr 11, 2011 | 08:01 AM
cibao2ner's Avatar
thats wat i wanna run on mines...how much did it run you for the box and 4 egts?are u getting temps from 4 gauges or tru laptop? you should contact a tuner or one of those tuning books...also try google...
Old Jan 19, 2012 | 10:05 AM
061000rr's Avatar
gonna bring this back. does anybody have any info they would like to share about egts and tuning? what are good numbers for diffrent fuels, maybe some tricks to keep them were you want them. and also does anybody know what weld bungs are needed and were to buy them? thanks. i just bought the aem 4 channel egt setup and im running aem v2 with the AQ1 data logger
Old Jan 19, 2012 | 10:49 AM
vtekthis's Avatar
The hotter the EGT does NOT mean its leaner< actually its fatter cause the probe in the pipe. Keep it under 1600-1700 and u be fine.
Old Jan 19, 2012 | 10:55 AM
061000rr's Avatar
1600-1700! i know this isnt a diesel but a diesel will melt pistons alot beefier than my **** at 12-1300
Old Jan 19, 2012 | 01:06 PM
blackeg's Avatar
the pistons wont melt at 1200. i usually wind up at around 750c or around 1400c at the end of a dyno pull.
egt isnt necessarily the best for afr tuning, but it can definately let you know when you've had load on the engine too long and need to get out of the throttle. even well tuned cars can have excessive egt if you are in it too long.
as said, stay below 1600f and you are ok
Old Jan 19, 2012 | 01:25 PM
061000rr's Avatar
lets say im going down the track and the aem sees it getting to hot. can the aem do something to cool it down without having to let off the trottle in the middle of a run?
Old Jan 19, 2012 | 02:45 PM
vtekthis's Avatar
if you had the EGT kit that i put together in my car, it has a programmable high warning output u could wire to do whatever you like.
Old Jan 19, 2012 | 03:14 PM
boostaout's Avatar
if you don't mind me askin what egt kit do you have
Old Jan 19, 2012 | 04:59 PM
ashtons300zx's Avatar
Yes the aem ems can correct fuel parameters up to an extent based on what you program it to do if you have the egt's wired into the aem ems. It cant do individual cylinder adjustment though. At least not the series 1. Dont know about series 2. But you can program it to add a certain percentage of fuel dependant on egt temps.
lil98civi
12
Jan 18, 2014 11:55 AM
Ash J. Williams
Dec 4, 2012 03:55 PM
RACEPAK
Apr 13, 2008 07:29 PM
jdmcrx1
Mar 6, 2004 09:12 AM
revo2001
Jun 8, 2002 05:13 PM
