e85
Old Dec 22, 2006 | 11:48 AM
fast is fun's Avatar
Default E85
http://www.nhrasportcompact.co...id=11
Old Dec 22, 2006 | 01:30 PM
dkim48's Avatar
Default Re: E85 (fast is fun)
sweet...they are allowing different rear ends now too for sport rwd!
maybe we will see some competitive s2k's now?
Old Dec 22, 2006 | 02:19 PM
Drag Race Inc's Avatar
Default Re: E85 (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">And Julies car going mid 8's </TD></TR></TABLE>
She is not driving for Easy Street anymore.
Also, glad to see them approve this. I have pushed for it since last season. I did testing and it did make more power.
Old Dec 22, 2006 | 04:51 PM
Suprdave's Avatar
How are they going to keep people from running E98?
Old Dec 22, 2006 | 04:55 PM
david@didrace.com's Avatar
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">How are they going to keep people from running E98?</TD></TR></TABLE>
By testing the fuel. All you need is a graduated cylinder and some water to test for ethanol percentage.
"A simple test a technician might use is to determine the amount of alcohol
present in gasoline. This can be done using a "water extraction method". A
graduated glass cylinder, usually 100 milliliters (ml), is used for the test. Place
100 ml of the gasoline sample in the graduated cylinder. Add 10 ml of water
into the cylinder, stopper the top, and shake thoroughly for one minute. Set
aside for two minutes. If no alcohol is present, the 10 ml of water will settle to
the bottom of the cylinder. If alcohol is present the alcohol will drop to the
bottom, along with the water, increasing the bottom layer to greater than 10ml.
Subtract 10 from total bottom layer and remainder will be the percentage of
alcohol in the gasoline. "
Easy way to test if the E85 at the pump is straight E85 or the 'winter mix' 70% ethanol/30% gasoline.
I guess you can also use that to get huge batches of moonshine at the pump.
Old Dec 22, 2006 | 05:02 PM
Suprdave's Avatar
Default Re: (david@didrace.com)
I know how they test it...but I just kind of doubted they would fuel-check every Sportsman car. We will see tho I guess...
Old Dec 23, 2006 | 05:48 AM
Bisimoto's Avatar
That is wonderful news!
Go green!
Old Dec 23, 2006 | 05:52 AM
SpeedDreamz.com's Avatar
instead of "Got Rice?" now "Got Corn?"
Old Dec 23, 2006 | 07:22 AM
tony1's Avatar
Default Re: E85 (SpeedDreamz.com)
I wonder if anyone is going to make their own "E85"? Some E98 and some VP Import or C16
Old Dec 23, 2006 | 07:41 AM
Project-D's Avatar
What kinda of power do you think can be supported using E85 on 1600cc injectors?
B series of course...
650ish?
Old Dec 23, 2006 | 07:45 AM
tony1's Avatar
Default Re: (Project-D)
Yeah, 650ish. That's what the 8 injector manifolds are for.
Old Dec 23, 2006 | 07:55 AM
boostedh22a's Avatar
I figured they would have to allow this fuel since technically it's pump fuel....haha
I ran E85 and E100 (yes, you can get ahold of this when you live in a hillbilly state...lol) all last year. I love the fuel, inexpensive, not near as corrosive as meth, makes good power/torque, great detonation protection, little to no maintenance...and CHEAP!!!!!
Old Dec 23, 2006 | 08:03 AM
Project-D's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, 650ish. That's what the 8 injector manifolds are for. </TD></TR></TABLE>
Hondata will only control 4 injectors... Technically I could wire it up and have it control 8 using some FJO injector drivers. I was planning on staying on C16 next year, but E85 is looking interesting and easy to get my hands on.
Old Dec 23, 2006 | 08:08 AM
tony1's Avatar
Anything can control 8 injectors, just gotta get creative.
Old Dec 23, 2006 | 08:13 AM
Project-D's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Anything can control 8 injectors, just gotta get creative. </TD></TR></TABLE>
Exactly! Just gotta think outside the box....
Old Dec 23, 2006 | 08:17 AM
I have ran (4) 1600cc injectors on straight ethanol and 30psi of boost with no issues. E85 will be even less demanding on the injectors. Just some of my experience with it. The injector D.C. is really high, but Lambda still remains steady.
How much boost do you think you can safely run on E85, I wouldn't think it would be near as high as C16. I personally haven't gone over 25psi on E85.
Old Dec 23, 2006 | 08:24 AM
tony1's Avatar
Default Re: (boostedh22a)
The furthest i've gone so far is 26psi and 620whp.
Old Dec 23, 2006 | 08:35 AM
BIGTUNA's Avatar
Default Re: (tony1)
Where can you order E98 from? What company carries it?
Old Dec 23, 2006 | 08:47 AM
Call Wyoming Ethanol, they are the largest supplier of ethanol in the racing industry. But being from the midwest, it's amazing where you can actually get it from. I didn't want to pay for shipping, so I just started doing some reasearch and found a place local to buy it from.
http://www.wyomingethanol.com/ I forget the persons name to talk to there, but just tell them you are wanting to purchase ethanol for a race car, and I think they will put you through to him
Old Dec 23, 2006 | 10:13 AM
Default Re: (BIGTUNA)
they sale it at some gas staion all over the us it's a clean buring fuel some new cars or tuned to run it from the factory, E85 that is!
Not 98 % http://www.wyomingethanol.com
E85 there 2 staions with in 20mi's from my shop. $3.25 at pump
Old Dec 23, 2006 | 10:23 AM
tony1's Avatar
Default Re: (fast is fun)
haha, damn, E85 is $1.79/gallon here!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast is fun &raquo;</TD></TR><TR><TD CLASS="quote">E85 there 2 staions with in 20mi's from my shop. $3.25 at pump</TD></TR></TABLE>
Man,thats alot, its only $2.17 a gallon here. Meijer gas station sells it. Its typically about .10 a gallon cheaper than 87
Old Dec 23, 2006 | 10:48 AM
For the people wondering if E85 is near them check out this link
http://www.e85refueling.com/
Old Dec 23, 2006 | 12:03 PM
Default Re: (tony1)
this is utah they thing it's moonshine it's a sin tax <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">haha, damn, E85 is $1.79/gallon here!</TD></TR></TABLE>
Old Dec 23, 2006 | 12:56 PM
GDM S2K's Avatar
im just happy to see my car can use a different diff now. SRWD hear I come
