Dyno Tires?
Old Apr 14, 2008 | 12:10 PM
T4 Neon's Avatar
Default Dyno Tires?
What's a good 14" or 15" dyno tire? I'm sure a nice drag radial or something like the power street guys run would work great, but that seems like an expensive solution for the amount of use I'd get out of them. What do you turbo street guys with 700+ WHP use?
Old Apr 14, 2008 | 12:31 PM
dester223's Avatar
Default Re: Dyno Tires? (T4 Neon)
I had really good luck with the M&H 235-60-15 drag radials.
We would literally blow the 225-50-15 BFGs loose on the dyno even in the 600 hp range.
You can also air the slicks up to 30 pounds and dyno with those guys
Old Apr 14, 2008 | 12:36 PM
BoostedJeff's Avatar
Default Re: Dyno Tires? (dester223)
We got Joes old car to make 850+whp in 3rd gear on M/T 235/60/15 ET Street Drag Radials.
They seem to work very well.
T4 Neon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dester223 &raquo;</TD></TR><TR><TD CLASS="quote">I had really good luck with the M&H 235-60-15 drag radials.
Thanks, I'll look into the M&Hs.. I figured the soft rubber of the true slicks would not last long on the rollers.
Old Apr 14, 2008 | 12:56 PM
h22 civic's Avatar
yea def not good on the rollers but ahhh what ya gonna do i use a old set of nitto drag radials just for the dyno
Old Apr 14, 2008 | 03:46 PM
kevinwarren240's Avatar
on my 750hp auto srt4 i use some 26/10.5/16 ET STREETS bias ply's
Old Apr 14, 2008 | 03:52 PM
jj07's Avatar
OG Fabricator
Too bad you are soo far north. i would let borrow my (street tires) MH 235/60-14s on factory R/T wheels.
Old Apr 14, 2008 | 05:22 PM
Turbo-charged's Avatar
Default Re: Dyno Tires? (jj07)
i have heard horror storries running the m&h drag radials on the dyno.....and if i remember correctly they personally made a post here in the drag racing section saying not to use their radials on the dyno.
the MT radials seem to work really well on the dyno, we have had several 800+ horsepower cars using the same set on our dyno. we have run slicks on the dyno too but its pretty scary, especially seeing one come apart at the top of 4th gear in a 1200whp supra
Old Apr 14, 2008 | 06:00 PM
fmfkid250's Avatar
Default Re: Dyno Tires? (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i have heard horror storries running the m&h drag radials on the dyno.....and if i remember correctly they personally made a post here in the drag racing section saying not to use their radials on the dyno.
the MT radials seem to work really well on the dyno, we have had several 800+ horsepower cars using the same set on our dyno. we have run slicks on the dyno too but its pretty scary, especially seeing one come apart at the top of 4th gear in a 1200whp supra </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1961929
Old Apr 14, 2008 | 06:15 PM
ALL IMPORT's Avatar
slicks work but u better be ready 2 start sweeping the whole shop floor, it gets old!!!
edsperformance
Jun 10, 2010 04:43 AM
blackpearlcivic
Feb 4, 2008 03:13 PM
ALL IMPORT
Jun 9, 2007 02:49 PM
rizen
Sep 28, 2006 09:21 PM
9SECQTR
Jun 11, 2004 12:53 PM
