CSS Block Users Unite !!
Old 04-23-2013, 04:31 PM
NewKlear's Avatar
Default CSS Block Users Unite !!
Just got my block in and was wondering how many people are rocking the css (cylinder support system). How much whp and times have been achieved with this support??
Old 04-23-2013, 05:45 PM
10sec4door's Avatar
Default Re: CSS Block Users Unite !!
I want!
10sec4door's Avatar
CSS can you please make a video showing the process.
Old 04-23-2013, 07:15 PM
4genaccordfreak's Avatar
Here you go.
https://honda-tech.com/forums/drag-racing-36/eggy-racing-shows-everyone-he-using-css-block-3139187/
This car makes 800whp on the dyno, run's low 9's in the 1/4.
Old 04-24-2013, 06:25 AM
NewKlear's Avatar
Thanks, for the link... It seems like there's not that many users out..people must likely do sleeves but this seems like a good solution for the budget racer...
Old 04-24-2013, 07:32 AM
EJ1_Ex's Avatar
it was either CSS block or GE sleeve for me. Then I decided to go with GE sleeves. CSS seems very promising though. We will have to see how long these blocks will hold
Old 04-24-2013, 07:36 AM
MugenSpeclNY's Avatar
did you have the finished machine work done by cncwerx? decking and beveling of the coolant ports?
Old 04-24-2013, 08:57 AM
ls_on_boost's Avatar
friend of mine has this block the car ran 9.75 with 600hp
Old 04-24-2013, 09:05 AM
NewKlear's Avatar
Yeah, they did the decking and coolant ports !!!
Old 04-24-2013, 09:25 AM
bauergold's Avatar
Looks awesome. I know what I'm going with.
Old 04-24-2013, 09:44 AM
Charlie Moua's Avatar
In.
Old 04-26-2013, 05:25 AM
VtecCarHauler's Avatar
Our next block will be CSS. Our stock sleeve coupe is at 620whp and just broke into the 9's 24.5 tire, oem gears, 2300lbs. I've heard eggy civic coupe is putting down 800whp on the CSS block running low 9's. Can't wait to get a CSS block, new turbo setup, trans gear set and go for low 9's. Eggy racing coupe might possibly go 8's with the CSS if they keep at it.
Old 04-26-2013, 09:54 PM
nitrousb20_vtec's Avatar
how n where can i get my block done n price also?
Old 04-27-2013, 01:52 AM
NoWorry's's Avatar
Interested in this blocks average max capabilities!
Here's the link to there site where you can have the service done and a link showing a CSS block split down the middle showcasing how deep the support goes along the cylinder. They seem pretty badass
http://www.cylindersupportsystem.com/
https://honda-tech.com/forums/drag-racing-36/cncwerx-css-block-cut-half-3042021/
Old 04-27-2013, 04:33 AM
H2BJON's Avatar
I hope everyone knows that this CSS process was originally created for street cars that wanted to safelty make 400-600 without buying full sleeves. Its true eggy has been running low 9s for a couple season but that's with a lot of R&D. Figure I clear that up before people start to think they can buy a 400$ block and start doing 30psi pulls right off the bat. Either way you look at it, this is the best thing that could have hit the market for us low budget guys
Old 04-27-2013, 05:35 AM
methodz55's Avatar
It's a nice piece for a street car if 10.5s or lower 600hp +is what people are looking for then fork out the few hundred more for a sleeved block CSS 650+ shipping vs 1100 + bore n hone but for street seems perfect my only problem is cant rebore like a sleeved block 81mm-85mm
Old 04-27-2013, 12:53 PM
GEN2 LS's Avatar
you can do a overbore on a CSS block as long as it's within the service limit of the oem sleeves, so if you have a stock 81mm bore LS block if the machinist can get a nick out without surpassing 82mm bore you can run the block again.
Old 04-28-2013, 08:42 AM
TeranceFL's Avatar
Just got my block back from CSS still need to get decked&bored hoping to make low 600s if not high 500s
Old 04-28-2013, 09:06 AM
NewKlear's Avatar
Nice!! Post pics when you get it decked. ^^
Old 04-28-2013, 07:02 PM
TeranceFL's Avatar
will do but probably wont be for a while, I sort of check to check lol
Old 04-30-2013, 05:51 PM
1991civicsi's Avatar
D series done up
Old 05-01-2013, 04:58 AM
061000rr's Avatar
does anyone daily drive these? have a customer here in nc that drives his car everywhere. have a block boxed up ready to ship to cnc werx but im afraid he will have issues with cooling just like a closed deck sleeved motor.
Old 05-01-2013, 06:25 AM
NewKlear's Avatar
You will loose some of your cooling, you will need to upgrade your cooling system to like a 2 core aluminium radiator and fans etc...
Old 05-01-2013, 08:09 AM
trickeng's Avatar
It is no way like a closed deck sleeve. The aluminum support ring actually draws heat from the cylinders faster than the water does and alum transfers heat nearly 6x faster than cast iron. This exceptional heat transfer to the outside of the block, allows water to do an even better job of keeping engine temp consistent.
Customers call me all the time and tell me they can't believe how cool the cars stay on the dyno unlike the sleeved cars.
Old 05-01-2013, 08:42 AM
Moderator
crazes's Avatar
because of the good transfers it something that needs to pay attention in cold weather? letting the car warm up longer?
Quick Reply: CSS Block Users Unite !!
