double clutching
Old Mar 15, 2004 | 07:19 PM
deeweezy's Avatar
Default double clutching
what is double clutching and how do you do it?
Old Mar 15, 2004 | 07:27 PM
98gsrTEG's Avatar
Default Re: double clutching (deeweezy)
i see you just got done watching the fast an furious eh?
it is what you do to shift in a car that has no syncros. push the clutch in once to take it out of gear an once to put it in. all it will do for you is make you look retarded and make you go slower
Old Mar 15, 2004 | 08:09 PM
bradford's Avatar
Default Re: double clutching (98gsrTEG)
It is used to save your synchros when downshifting By stepping the clutch, putting it in neutral, then clutch again and putting in a lower gear, it speeds up the lower gear to the same speed as the gear your in without using your synchros, thus saving them. Track racers use this to save rebuilds on their trannies since they shift so much.
Old Mar 16, 2004 | 12:43 AM
rYduckz's Avatar
Default Re: double clutching (bradless)
"granny shifting not double clutching like you should"
Old Mar 17, 2004 | 08:17 PM
hair_rice's Avatar
Default Re: double clutching (mRbojangles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mRbojangles &raquo;</TD></TR><TR><TD CLASS="quote">"granny shifting not double clutching like you should" </TD></TR></TABLE> funny ****!
philkehn
Oct 27, 2006 06:58 AM
z51LS2
Apr 16, 2006 05:17 PM
ablack934doorcivic
Nov 1, 2005 02:02 PM
DIP_SET FoReVr
Jun 10, 2004 12:30 PM
canadaitr
Mar 24, 2003 07:17 PM
