shift problems?
Old Jun 10, 2004 | 10:41 AM
DIP_SET FoReVr's Avatar
Default shift problems?
hey whats up, i have a 95 civic with manual transmission. should you be able to go into neutral without stepping on the clutch? if not than whats up?
Old Jun 10, 2004 | 10:56 AM
jerbear!'s Avatar
you can go into any gear (or nuetral) without the clutch. if ur putting it into a gear without the clutch then as long as ur rev's match then you're good 2 go
Old Jun 10, 2004 | 12:10 PM
Deemeetree's Avatar
Electrician
Play it safe, use the clutch ALL the time.
Old Jun 10, 2004 | 12:25 PM
Default Re: (Dimi)
i do use the clutch all the time, i just wanted to know if it was normal for it to do this, because on my dads saab you cant go into neutral without stepping on the clutch.
Old Jun 10, 2004 | 12:27 PM
Deemeetree's Avatar
Electrician
From a gear to Neutral, you can. Into a specific gear, it's risking it.
Old Jun 10, 2004 | 12:30 PM
Kamin's Avatar
Default Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! &raquo;</TD></TR><TR><TD CLASS="quote">you can go into any gear (or nuetral) without the clutch. if ur putting it into a gear without the clutch then as long as ur rev's match then you're good 2 go</TD></TR></TABLE>
there is a good reason our cars have clutches. use it. ill garuntee every time you do that you are shortening the life of the transmission, even if you dont hear a grind. dont be a dumbass.
yes its normal to be able to slip the shifter into neutral but DO NOT DO IT. use the damn clutch.
Andrew
Jul 26, 2006 02:40 AM
ablack934doorcivic
Nov 1, 2005 02:02 PM
crxaddikt
16
Apr 4, 2002 05:25 AM
DualKnuttz
Dec 12, 2001 09:46 PM
FlipboiGSR
Sep 12, 2001 09:07 PM
