double clutching
Old Jan 28, 2003 | 08:04 PM
binkster's Avatar
Default double clutching
What EXACTLY is double clutching? I have head numerous explinations, none of which are the same.
Old Jan 28, 2003 | 08:13 PM
all stock's Avatar
Default Re: double clutching (binkster)
when u are gasing it, in a gear and step on the clutch and release for a brief period, causing the rpms to jump and supposedly gain more pull from the second catch. personally, i don't thi nk it works. powershifting...that's something else.
Old Jan 28, 2003 | 08:16 PM
FCdrifter's Avatar
New User
Default Re: double clutching (all stock)
_______
interesting....
Double Clutching as I've always known it:
1. run out gear
2. push in clutch and put car in neutral
3. release clutch
4. push back in clutch and throw in the next gear
It's useful for rev matching in autox/open track so you don't disrupt the car and when your syncros start taking a **** on you.
Old Jan 28, 2003 | 08:36 PM
kentucky accord's Avatar
Default Re: double clutching (fcdrifter)
1. run out gear
3. release clutch
thats what most people consider double clutching. DC is also used in vehicles with heavy clutch systems(big rigs, dump trucks, etc.), although most big truck drivers dont use the clutch except from a stand still.
Old Jan 29, 2003 | 09:56 AM
GoLowDrew's Avatar
Old Member
25 Year Member
so which is it?
Old Jan 29, 2003 | 11:01 AM
4piston's Avatar
Default Re: double clutching (GoLowDrew)
It is pushing the clutch in to put the tranny in neutral, letting out on the clutch in neutral, and pushing the clutch back in to move to the next gear.
Big trucks don't have synchros in the trannies. You have to double clutch them in order to match engine speed and to get the tranny in and out of gear. You don't double clutch a car.
This is the ONLY definition of double clutching.
Old Jan 29, 2003 | 11:43 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: double clutching (Frankenstein)
Then why do so many people here talk about it?
Old Jan 29, 2003 | 11:47 AM
hondaswaper's Avatar
cause to many people watch F&F.........
Old Jan 29, 2003 | 12:41 PM
Veil_Side_'s Avatar
Default Re: double clutching (hondaswaper)
From my understanding, Double Clutching should be used when turning like on a road/track so that you have smoother transitions between gears especially when downshifting. Now unless you plan on shifting 1st, 2nd, 3rd, and then back to 2nd again...I don't think you need it for drag racing.
Old Jan 29, 2003 | 12:43 PM
MrBite's Avatar
Right
Right, at least from what I've heard
Wrong
Double clutching in a car is usually associated with downshifting, not upshifting/drag racing a la F&F--blip the throttle once the shifter is in neutral and the clutch is engaged, and then you clutch in/downshift/clutch out. It's useful on older cars with crap/no synchros, or maybe on an autox course if you want to go to first, or if you're going down more than one gear...
basically it means that not only is the engine rev-matched, but the transmission's gearshafts are rev-matched too. It's not widely used on modern cars with good synchros though.
[edit]
uhh...not so much.
[Modified by MrBite, 4:44 PM 1/29/2003]
Old Jan 29, 2003 | 01:29 PM
Draglab01's Avatar
Default Re: double clutching (Veil_Aluminum_Siding_)
For that I always use the heel and toe method
Old Jan 29, 2003 | 02:17 PM
dmotoguy's Avatar
Default Re: double clutching (Draglab01)
thats for downshifting while braking...
will rockit
May 7, 2015 08:00 PM
TheSickestDC2
Dec 20, 2009 06:44 PM
1hgej1
Mar 30, 2009 09:55 AM
-BlueGSR-
May 1, 2003 09:27 AM
civicheaven151
17
Jul 6, 2002 07:25 PM
