Does traction effect mph?
Old Nov 13, 2004 | 07:06 AM
  #26
200.108.10.148
Guest
Posts: n/a
Default Re: Does traction effect mph? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">
Obviously you need traction to gain mph. Which is why spinning will really only gain mph for you if you spin in the first 100' of the track. The first 100' barely effect's your mph but hugely effect's your ET.</TD></TR></TABLE>
Old Nov 13, 2004 | 08:02 AM
  #27
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Does traction effect mph? (stollin)
I officially think ive seen it all with this post...
BTW, DiRep is a timeslip *****...
Old Nov 13, 2004 | 02:47 PM
  #28
phat51's Avatar
Seems everyone is forgetting about the basis of movment which is torque, with the lower torque, most fwds have to spin off the line to get the engine in the peak tourque range wich allows the tire speeds to increase but ground speed stays low, once the tires hook up the car accelerates quicker but with a lower et due to the time lost while it was spinning. My .02
Brad
Old Nov 13, 2004 | 03:23 PM
  #29
park83rsx's Avatar
the less traction you have the higher your trap speed will be.... it gives you more time to get speed up
Old Nov 14, 2004 | 08:15 AM
  #30
DD_JonnyLee's Avatar
Default Re: (park83rsx)
he wasnt talking about 98 in the 1/4 . thats his 1/8 mph.
just clearing that up
-jonathan
Old Nov 14, 2004 | 08:48 AM
  #31
SuperTeg95's Avatar
Default Re: (JonnyRocket)
Yes, thank you. I meant 1/8th.
Old Nov 14, 2004 | 04:50 PM
  #32
RMF
Guest
Posts: n/a
Default Re: (SuperTeg95)
Its not that your speed goes up ,your e.t. goes up.Your 1/4 mile speed will be close to what it always is, but your e.t. will be higher from the tires spinning.
Old Nov 14, 2004 | 06:10 PM
  #33
phat51's Avatar
yeah sorry I ment et will go up, my cars will run about the same et but the mph is about 20-30 lower than the lower torque fwds
Old Nov 14, 2004 | 07:02 PM
  #34
200.108.10.148
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by park83rsx &raquo;</TD></TR><TR><TD CLASS="quote">the less traction you have the higher your trap speed will be.... it gives you more time to get speed up </TD></TR></TABLE>
you wrong...speed = time/distance
Old Nov 14, 2004 | 07:23 PM
  #35
UnKnownUser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">Heres my take on the subject. Lets forget about traction for a second. Just think of your engine accelerating in terms of rpm's over time. Assuming power stays the same, the amount of time it takes for the engine to accelerate from 1k rpm-9k rpm should always be the same. The more traction you have the quicker you go down the track. (less time to accelerate.) The less traction you have the slower you go down the track. (more time to accelerate.)
Old Nov 14, 2004 | 07:44 PM
  #36
RMF
Guest
Posts: n/a
What do you mean more time ?You have A 1/4 of a mile.What does time have to do with it.You have from point A to point B.The sooner you get there the faster you will be going.If you loose traction,your not going to go faster it will just take you longer.
Old Nov 14, 2004 | 08:36 PM
  #37
Default Re: Does traction effect mph? (RMF)
That is what he and all of us are saying...
Old Nov 14, 2004 | 09:02 PM
  #38
RMF
Guest
Posts: n/a
Default Re: Does traction effect mph? (LSVTEC_DC4)
What was said was ,If you spin the tires you go faster.Anyway I think everybody gets it
Old Nov 14, 2004 | 09:10 PM
  #39
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">
What do you mean more time ?You have A 1/4 of a mile.What does time have to do with it.You have from point A to point B.The sooner you get there the faster you will be going.If you loose traction,your not going to go faster it will just take you longer.</TD></TR></TABLE>
thats the wrong way of wording it, "gaining mph". I shouldnt have said that. You just get back mph that was already there, that you would have lost if you hooked off the line harder. The harder you launch, the less time and distance you give your engine to accelerate down the track.
Modified by DIRep972 at 5:06 AM 11/15/2004
Old Nov 14, 2004 | 09:13 PM
  #40
SlicksMH's Avatar
This is a good post and you know what you are all right. Their is sooooooooo many factors here, this post can go for years. to all of you.
John@M&H-Hashims
boostjunkie757
Mar 21, 2014 05:04 AM
turtle-eg
Nov 13, 2005 02:41 PM
BLK99VTECR
Oct 28, 2003 09:53 PM
TurbodCX
Jun 28, 2002 05:08 AM
CRXRageD
May 6, 2002 08:27 AM
