cut doors
Old Aug 17, 2006 | 06:42 AM
91integraLSVTEC's Avatar
Default cut doors
Has anybody removed there side impact beams from there doors to save weight?
Old Aug 17, 2006 | 06:48 AM
b18bturbo's Avatar
Default Re: cut doors (91integraLSVTEC)
its easy way to reduce weight only issue is the door become flimsy but overall it not bad way to reduce weight quickly
Old Aug 17, 2006 | 07:02 AM
AllMoToRB18c's Avatar
Default Re: cut doors (b18bturbo)
i think its a good way to say weight and i havent had any problem with the door becoming flimsy
Old Aug 17, 2006 | 07:16 AM
94 si hatch's Avatar
so how much do the beams actually way?
Old Aug 17, 2006 | 07:19 AM
DARKB20's Avatar
Default Re: cut doors (AllMoToRB18c)
What are other ways to cut weight from civic/integra?
Old Aug 17, 2006 | 07:23 AM
redboost10's Avatar
Default Re: cut doors (oldschool310)
remove unnecessary brackets throughout whole car, get crazy with the plasma on the bumper supports, clean up the wiring harness, remove sound deadening stuff under carpet, remove heater, remove thick black mat on firewall
Old Aug 17, 2006 | 07:24 AM
never actually weighed them by themselves...just had everything in a box that i took out for the day...i would say like 8-10lbs. each
Old Aug 17, 2006 | 08:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">its easy way to reduce weight only issue is the door become flimsy but overall it not bad way to reduce weight quickly </TD></TR></TABLE>
How is removing the beams an easy task since there tack welded to the door?
Old Aug 17, 2006 | 08:54 AM
b18bturbo's Avatar
its not hard to do if you have nice sawzall and soem time
Old Aug 17, 2006 | 08:56 AM
just have to drill out the spot welds and cut the bar in half and cut out a little bit of the door to slip out the bar once you cut it
Old Aug 18, 2006 | 06:20 AM
k-series's Avatar
Won't you ruin the door skin or is it not tack welded to the skin?
Steve
TEAM ASSASSIN SI
Mar 7, 2011 10:12 PM
gwiffer
12
May 16, 2007 07:24 AM
archmage
Jul 20, 2005 01:08 PM
mgags7
Dec 18, 2004 11:53 PM
4doorH22
Sep 29, 2002 02:37 PM
