cryotreating syncros?
Old May 10, 2004 | 05:24 PM
  #26
whatVTEC's Avatar
Default Re: cryotreating syncros? (SEFIxCivic)
what does cryo do? Is it only needed for high horsepower cars? If i replace the parts needed and then get cryo done does it make it stronger to prevent it from happening? Sorry for the questions, but I just wanna understand what the cryotreatment is for.
Old May 10, 2004 | 06:29 PM
  #27
JICsube's Avatar
Default Re: cryotreating syncros? (whatVTEC)
kinda off topic but you get the point. they cryo treat the sti ra gears from ralli spec and the subaru guys have had good luck with it with 350plus whp. only one guy known to break so far and i think he was running like 450whp.. so it must help
Old May 10, 2004 | 07:56 PM
  #28
E-Town4229's Avatar
Default Re: cryotreating syncros? (SIXTYdashONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">Am i the only one here that thinks this is overkill?
I havent had a bit of problems with my tranny grindin, not ever, once... </TD></TR></TABLE>
if you drive your car ALOT and beat on it ALOT. you can wear out the synchros and start to grind gears. fairly recently it was common to see relativly stock 99-00 Sis coming in with transmission problems. just about every single one had a bad 3rd gear synchro due to severe abuse (evidenced by the bald front tires although there are the exceptions where maybe its just a bad driver). repeated high rpm power/speed shifts will wear out synchros. the solution is products like gear speed or libertys upgrades.
-Roger
Old May 10, 2004 | 10:13 PM
  #29
V-SPEC 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatVTEC &raquo;</TD></TR><TR><TD CLASS="quote">what does cryo do? Is it only needed for high horsepower cars? If i replace the parts needed and then get cryo done does it make it stronger to prevent it from happening? Sorry for the questions, but I just wanna understand what the cryotreatment is for. </TD></TR></TABLE>
Cryo treating is for wear resistance on parts. It's not really making it stronger, it's like an antiwear process.
V-SPEC
Old May 11, 2004 | 12:35 AM
  #30
TEAMGENDAI's Avatar
Default Re: cryotreating syncros? (boostedb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">
V-SPEC</TD></TR></TABLE> EXACTLY
Old May 11, 2004 | 06:36 AM
  #31
whatVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEFIxCivic &raquo;</TD></TR><TR><TD CLASS="quote">anyone in the bay area need your tranny parts cryoed? i can help u out.</TD></TR></TABLE>
How much?
Old May 16, 2004 | 02:36 PM
  #32
project dc2's Avatar
How much? </TD></TR></TABLE>
same here, also is it better to have the tranny apart or deos ti not matter ?
Old May 16, 2004 | 02:51 PM
  #33
SEFIxCivic's Avatar
Default Re: cryotreating syncros? (project dc2)
the gears must be taken apart. if you bring me the tranny i can disassemble it for u as well as inspect it for wear
Old May 16, 2004 | 04:02 PM
  #34
i wanted to shotpeen and cryotreat a SR20 FWD tranny.
Old May 16, 2004 | 04:33 PM
  #35
SEFIxCivic's Avatar
i dont have experience taking apart a sr20 transmission. if you take it apart i can get your stuff cryoed.
Old May 16, 2004 | 05:26 PM
  #36
E-Town4229's Avatar
forward motion did some cryo work on an sr20 trans. although i think you have to send them the parts.
-Roger
Old May 16, 2004 | 07:06 PM
  #37
Default Re: cryotreating syncros? (E-Town4229)
price ?
Old May 17, 2004 | 08:20 PM
  #38
whatVTEC's Avatar
so how much would it be for disassemble,inspect and cryotreating?
Do you work out of R crew? If so can you also get me a price for Type R LSD and installation in a GSR tranny.
Thanks
Old May 17, 2004 | 11:46 PM
  #39
SEFIxCivic's Avatar
call dan tomorrow on the disassembly, inspection, lsd, and install.
if you can do the cryotreat within this week i can get it done for $200 bucks. otherwise it will be $250.
thats for the final drive, 1-5 gears, mainshaft, countershaft, shift forks.
Old May 20, 2004 | 09:09 AM
  #40
hybrid901's Avatar
I had mine cryoed at http://www.deepfreezecryo.com
Old May 20, 2004 | 11:23 AM
  #41
PM-Performance's Avatar
Default Re: cryotreating syncros? (hybrid901)
WOW&gt; they said Like $10 a piece to do the syncros, and if i wanted my whole gear box done it would be $125. THATS NICE!!!!!
EGgarniEG
Jun 13, 2007 04:44 PM
Heylookits shawn
Sep 26, 2005 05:39 PM
machine4321
Mar 11, 2005 11:57 AM
inTeGra_LivesOn
10
Oct 23, 2004 07:43 AM
Bulldogg83
Apr 15, 2004 03:37 PM
