CLUTCH STOP
Old Mar 1, 2012 | 05:01 PM
buustedEG's Avatar
Default CLUTCH STOP
ABOUT TO FINISH UP MY TRUESTREET CAR..WAS WONDERING IF YOU GUYS CAN POST SOME DETAILED PICS OF YOUR CLUTCH STOP SET UPS ...I HAVE A EG HATCH 1995...THANKS IN ADVANCE
Old Mar 1, 2012 | 05:37 PM
SPOOLINmatt's Avatar
Default Re: CLUTCH STOP
my clutch stop consists of just adjusting the clutch pedal down til it bottoms out on the floor at the right time. There is no need in adding hardware.
Old Mar 1, 2012 | 06:12 PM
portenio78's Avatar
I simply have the pedal set, right where I like it, then have a very small peice of 2x4 screwed into the back side of the carpet where you cant see it. Pedal has a nice soft feal when it hit the carpet/wood.
Old Mar 1, 2012 | 07:37 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Here's what you asked. Is it necessary, no it isn't but it def doesn't hurt ANYTHING by having one.
Basically it's adjustable as you can see so when the clutch wears down or I go to a diff clutch it can be adjusters as well. Then it's held down by a 10mm bolt. I'd rather not take a chance of over extending anything.
Old Mar 1, 2012 | 08:00 PM
a1320addict's Avatar
um...
Few easy ways to get it done, either modify the pedal, or as ahobbs posted, make a riser off the floor board.
You can also remove the clutch inhibiter switch on the pedal bracket and use a M12 bolt.
Old Mar 1, 2012 | 08:29 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I know a few who do the bolt or weld a bolt on the pedal.
Old Mar 2, 2012 | 12:46 AM
.CUBISH.'s Avatar
i have a welded nut on the pedal with a threaded rod and lock nut..... its a pretty basic thing to figure out
Old Mar 2, 2012 | 04:16 AM
Originally Posted by a1320addict
um...
we've adjusted 3 cars this way. It works the exact same, its free, and its easy.
Old Mar 2, 2012 | 04:21 AM
NY GsR's Avatar
nicee
Old Mar 2, 2012 | 05:18 AM
acup22's Avatar
Originally Posted by NY GsR
nicee
this is simple and clean I d rather do that who sells this clutch stop
Old Mar 2, 2012 | 05:52 AM
89efhatchy's Avatar
x2
Old Mar 2, 2012 | 06:44 AM
buustedEG's Avatar
Can someone post pics installed....or with the clutc switch location being used
Old Mar 2, 2012 | 11:08 AM
bads2k's Avatar
Since this topic is up. How are you guys adjusting the pedal stop on a dogbox? When are you realizing where to set it at?
Old Mar 2, 2012 | 11:11 AM
YZFR6's Avatar
Paul is doesn't really matter on transmission, but the spot where it will engage into gear. Once you get that engagement spot, you wanna go about 1/4" past that and that is where your pedal stop should be. Make sure everything is bled properly. Hope that helps.
Old Mar 3, 2012 | 06:59 AM
1qkfodo's Avatar
is it necessary to put a clutch stop on a cable tranny?
Old Mar 3, 2012 | 07:24 AM
DeLucia's Avatar
It has nothing to do with the tranny, it's about what twin disc your running. I know CC requires a stop
Old Mar 3, 2012 | 07:27 AM
hush22's Avatar
Originally Posted by 89efhatchy
x2
This is how I did it on an EF or DA really simple. This is on a Hydro conversion but can work the same I suppose
The Bolt and Nut on the clutch arm is stationary, The M12 x 1.25, which can replace the NSS, is what will be adjusted in or out. Its really simple but affective
Heres a video. Im not the best commentater but at least you get an idea.
http://www.youtube.com/watch?v=flhJA...F7S_W41WoMyqAl
Old Mar 3, 2012 | 07:41 AM
89efhatchy's Avatar
Oh nice. Thanks for that info!
Old Mar 2, 2013 | 10:38 PM
biglurktm's Avatar
Here's what i planned on doing, I have a EK Hatch, and running the comp twin. Could i just replace Clutch switch A with a bolt long enough to hit the medal part on the clutch, or have to run two bolts for it
Here's a picture of what i'm taking about
I removed Switch A also.
Old Mar 3, 2013 | 02:21 AM
DraginX's Avatar
I usually weld a nut on the pedal assembly right about the area of logo A in the picture of the previous post and use a piece of threaded rod on the end with a lock nut on the pedal side of the assembly. I'll be doing one sometime soon and I'll snap some pics and post it up.
Old Mar 3, 2013 | 06:05 AM
eviltwin66six's Avatar
I have to do this also is my 88 crx
Old Mar 3, 2013 | 06:19 AM
^^^^ lol
Old Mar 3, 2013 | 06:33 AM
nonvtecallmotor's Avatar
This is how my car is done aswell.
I had a long bolt in where the clutch switch was but that was a pain in the *** to adjust.
Old Mar 3, 2013 | 12:56 PM
DraginX's Avatar
Here's how I usually do them, looks like it might be in the way of your foot but it isn't even close, and it stops on the rubber that the clutch arm normally stops on.
Still needs to be cleaned up.
Old Mar 3, 2013 | 04:55 PM
biglurktm's Avatar
This is how i did mine in my EK Hatch. Pretty simple just a pita to get the clutch pedal out from the firewall.
tigueremalo
Jan 14, 2007 02:29 PM
Kermit EK
Jan 29, 2003 03:02 PM
Steve
Jul 23, 2001 01:42 PM
