Clutch masters FX600 user claim in plz
Old 06-23-2012, 11:57 PM
Wanchai's Avatar
Default Clutch masters FX600 user claim in plz
Is this usual for cm clutch? im very **** off now.
I have to find new tranny,and new radiator,and clutch now
this is the last time i use alu flywheel if this gonna be this way.
Old 06-24-2012, 12:27 AM
rudebwoy's Avatar
Default Re: Clutch masters FX600 user claim in plz
wow! that is some serious damage, hope CM take responsibilty and compensate you, and aluminum flywheel is the worst thing to use on any car making power, or driving fast anyways.
Old 06-24-2012, 12:57 AM
SonicRacing1's Avatar
How much power is ur car making? what was the car doing when this happend? Thats alota damage
Old 06-24-2012, 01:03 AM
Wanchai's Avatar
701whp today. My first pass yesterday and clutch detonate before 1/8 mile
Old 06-24-2012, 01:05 AM
First.EG's Avatar
damn that sucks. that way i bought an exedy flywheel.
Old 06-24-2012, 01:08 AM
Damm thats sum nice power, I myself have never used CM we usaully use Competition Clutch or Tilton Clutch
Old 06-24-2012, 04:51 AM
Boostedld9's Avatar
I ran the fx700 in my car with the same type flywheel design and never had a problem, car made 550 and did probably close to 20passes. Thats kinda scary, I just bought another fx700 for my new engine and asked for a steel flywheel but one wasnt avalible for my car. I would call clutch masters and tell them what happened because in no way is that user error thats their part failing. I wish you luck.
Old 06-25-2012, 08:05 AM
a267mm's Avatar
ran a fx725 with a flow control valve on a vr6 car never made over 200whp cause was never tuned right. clutch took a **** in 2-3months. called them and they blamed it on the tune. shipped them the whole clutch kit had, to buy a rebuild kit they had, was built in house get it back installed it didn't wanna go into gear after that. Had to turn it off and put it in gear a start the car so it can drive.
Old 06-25-2012, 10:51 PM
Wanchai's Avatar
Well i have to try another brand now. thinking to try tilton or cc clutch
Whats is the best for me?with steelflywheel ofcurse.
Old 06-26-2012, 06:12 AM
BEfab's Avatar
How much TQ?
Old 06-26-2012, 10:22 AM
Wanchai's Avatar
498 fotpound
Old 06-27-2012, 05:36 PM
h22-eg-hatch's Avatar
Act Chromoly flywheel ftw
All aluminum flywheels are pretty weak...
I've seen aluminum flywheels break with less then 250 ft lbs a tq
Old 06-27-2012, 06:12 PM
DDTECH's Avatar
....what??
Its racing..This type of stuff happens..its a shame it did happen, but a comment like that isn't needed..
Old 06-27-2012, 06:41 PM
Twenty47's Avatar
makes me feel better about dropping 150 on a scatter shield lol
Old 06-27-2012, 07:09 PM
Kevin's Avatar
.cubish. had the same thing happen to his. The one they sent to replace it was a different design.
Old 06-30-2012, 09:07 AM
rudebwoy's Avatar
Originally Posted by ALL M0T0R
....what??
still stand firm with my comment, the only thing in your motor that should be made of aluminum is the outside of your block, alluminum transmission case, your head,your pistons, motor mounts. anything else is not a smart idea and I still think CM should take fill responsibility.
Old 06-30-2012, 09:22 AM
rudebwoy's Avatar
....what??
plus on one pass, and maybe 2 hours on the dyno. come on now! this should not have happen this early.
Old 06-30-2012, 09:37 AM
AllShowNoGo727's Avatar
For the price and the different options they have in twin disk clutches, you should check out Competition Clutch.
Old 06-30-2012, 10:07 AM
BoostR41's Avatar
....what??
It is needed. That clutch is rated for a good amount of power and it came apart. That is a parts failure regardless of racing or not. Had it come through the bellhousing all the way that is a danger to the driver and spectators and should be fixed
Old 06-30-2012, 10:13 AM
utahturbosohc's Avatar
Aluminum flywheel cannot be blamed for this...
All bolts on the flywheel to crank were tight? how about pressure plate to flywheel? There are so many other factors that could come into play.
But, Instead of looking at any other possibilities, lets just bash the company that made the product that could have been installed incorrectly, etc.
Old 06-30-2012, 10:56 AM
Wanchai's Avatar
All bolt is tight with locktite (flywheel to crank,Pressure plate allso), you can se on the flywheel that the ring gear has been ripp off from alu flywheel.
Anyway this is the last time i use alu pressure plate, Billet steel is the way to go.
Old 07-01-2012, 03:06 AM
rudebwoy's Avatar
Take a closer look at the damaged parts. nothinh in that pic is user/installer error, when you buy a flywheel are you required to install you own ring gear? answer no! the ring gear ripped off the flywheel, (user error could be blamed if the flywheel to crank bolts came loose, or pressure plate to flyweel came loose, or did the driver engage the starter while at full speed,no proof. other than that its a product failure.) I know its not my thread but dealers and manufacturers need to take responsibility for obvious product failure, and anything it damage in its failure. we do not know what CM take is on this issue, but I am just saying before we blame user/installer on everything we should really look at what part failed.
by the way I use CC twin plate clutch that got messed up after 10000 miles, caused of the damage was bad crank seal leaking oil on the plates,( clearly was a user/installer error) sent it in CC told me what cause the damage, and replaced all damage parts for a very reasonable price, without delay. checked everything else to make sure they were in correct specs, just saying maybe you should make your next clutch be from Competition clutch.
Old 07-06-2012, 12:22 PM
Ben Huynh's Avatar
This clutch is very old. The Clutchmasters twin disc clutches have since been redesigned with new discs and a single piece chromoly flywheel.
Ash J. Williams
Transmission & Drivetrain
09-15-2012 09:43 AM
sixandhishat
02-13-2009 10:36 AM
allmotor99lude
07-07-2005 08:01 PM
pub
08-11-2003 06:50 PM
MintyDip
13
07-15-2002 04:14 AM
Quick Reply: Clutch masters FX600 user claim in plz
