Broken axle help
Old Jun 11, 2010 | 12:12 PM
tagteamracing's Avatar
Default Broken axle help
hi i have a 95 civic with a d16 with 250whp and 240wtq
i have 2.9 dss axles and snaped my passanger side one last weekend. now dss went good for it thank you dss. but now i am worried about snapping another one. i thought with only 250whp and they are good for 475whp i thought i would never snap one. i have skunk2 pro c suspension lake wood tracktion bars bfg drag raidals lsd. shouldnt the tires break free before snaping a axle.
so i know you are supose to pre load the car but how should i do my burn outs they do not allow drag radials in the water box. any tip or trick so i dont break another axle would be great.
Old Jun 11, 2010 | 12:17 PM
flatblackhatch's Avatar
Default Re: Broken axle help
Real simple answer to that pre load your clutch when launching the car I've seen 500whp on stock axles doing just fine. Just search pre load to figure out how to do it.
Old Jun 11, 2010 | 12:21 PM
right i try my best to do that but i am worried that my burn outs are stressing the axles when i do my dry burn out i cant really get them to spin i just drag my rear tires.
also i would think the drives side axle would snap first seeing how its a lot longer then the passenger side.
Old Jun 11, 2010 | 12:26 PM
Before I learned how to preload the clutch I snapped a couple axles and they were all passanger side and all aftermarket axles. As far as the burnout goes I've never heard a track telling drag radial they cant use the water box. I hear street tires aren't allowed to I haven't really dealt with that issue I've been on slick the last 4 years.
Old Jun 11, 2010 | 12:36 PM
Garage 808 Hatch's Avatar
how low is your car?
Old Jun 11, 2010 | 01:22 PM
i have the skunk2 pro c and they are at there higest point so i think it droped the car around 2inched + - half inch
Old Jun 11, 2010 | 01:54 PM
h22apwrd95's Avatar
Wow, no DR's in the water box? I would check and see if they are letting the RWD cars on DR's hit the water box. Not saying they are biased, but it has happened at a local track here in Iowa also. Had to tell the water guy to spray the box. Really irritating. This was when I was helping a buddy with his hatch running low 7.0x in the 1/8th (on slicks). Makes for some serious stress on the cars that are just on the edge of really being able to power through a burnout.
Mike
Old Jun 11, 2010 | 02:02 PM
katch24's Avatar
What mounts are you using?drag raidals are hard on your drivetrain.
yeah i got to thinking and i think they are leting the rwd guys with dr go in the water so when i get my car up and runing i am going to bring it up the more i think about it when i went thought tech he was like yea street tires cant go thought the water box so i was like will dr are alowed on the streets so i was like w/e but now i am thinking he may have not know that they were dr not just regular street tires if i can go though the water do you think i would pick up to much water with the bfg?
Old Jun 11, 2010 | 02:05 PM
ran those tires did burn outs all day long in water and it hooked up just fine afterwards....dam not preloading killing a trans....
Old Jun 11, 2010 | 02:07 PM
i have a engine dampener right now with stock mounts but i have been waiting 3 weeks for my inovative mounts a little to late i wish they would come in before i head back out to the track i dont know what is taking so long to get them
Old Jun 11, 2010 | 02:08 PM
h22apwrd95's Avatar
You should not have a problem with it. They have less grooves and sipes than the older design BFG DR's. And those do fine on the strip.
Old Jun 11, 2010 | 02:10 PM
i am preloading but i dont think i am doing it enough i built this car over the winter never raced befor have only been to the track 4 or 5 weekends now still have a lot of learning to do
I ran all motor crv-tec with b16 trans stock mount exedy 3 puck... that thing was a axle snapping machine untill I learned preloading.
Old Jun 11, 2010 | 02:14 PM
i hear you i am trying my best but have no one to show me what to do so its all trial and error i am the only import everyone else at my track it a v8 with a auto they always have a joke about my car every sunday but when i get it down and start beating them it will be so great
Old Jun 11, 2010 | 02:17 PM
just hit first staging light slowly creep to second one as you it second one pull e brake up and keep the clutch where it is when light goes third yellows lit slide clutch out I stress slide clutch out and go.
Old Jun 11, 2010 | 02:46 PM
i get the theory now i just have to not get to excided and pop the clutch but i am trying
Tippyman
May 8, 2014 07:39 PM
lindseyhunt1090
Mar 4, 2013 05:41 AM
guessinthe2000
Honda S2000
Jul 26, 2010 04:50 PM
turboedsupe
Feb 9, 2009 11:43 AM
