Bogart Problem
Old Jun 22, 2002 | 03:56 PM
Reddog's Avatar
Default Bogart Problem
I just got a pair of 13 x 8 bogarts Dragon Flys. I have a 89 CRX with 94 Ls suspesion on the front. The Bogarts are hitting the brake calipier in the front . Do I need spacers or what . Please Help!!!!!!
Old Jun 22, 2002 | 04:57 PM
ExospeedAMcrx's Avatar
Default Re: Bogart Problem (Reddogallmtrcrx)
yup the bogarts are made with and without the BUILT in spacer.
if you have one that doesnt have the BUILTin spacer, you can get one from PEpBOYS or sumthing and use that to help clear the BRAKES.
Just remember that it would need a little bit longer lug nuts to compensate with the extra spacing.
Wil
Old Jun 22, 2002 | 09:43 PM
Reddog's Avatar
Default Re: Bogart Problem (exospeedAMcrx)
I have the skunk lugs that should be ok with a spacer correct
Old Jun 22, 2002 | 10:57 PM
havent used the skunk lugs before on Bogarts but as long as the Lug goes thru to the spacer, it should hold good.
Wil
Old Jun 23, 2002 | 12:37 AM
GokuSSJ4's Avatar
what bracking system are you running and if integra , then yes you need the spacer that comes build in the 13' bogards for clearence
Old Jun 23, 2002 | 12:39 AM
GokuSSJ4's Avatar
skunks studs should be fine , there long enough as long as you get enough turns and goes almost through the lug nuts . you should be fine
Old Jun 26, 2002 | 10:18 AM
rocket_R's Avatar
Default Re: Bogart Problem (Spoon1)
hey where you get your bogart rims? i'm looking for some in 15in for my type R. let me know
Old Jun 26, 2002 | 10:46 AM
hybridreams's Avatar
Default Re: Bogart Problem (rocket_R)
IM exospeedAMcrx (Wil)
540dude
Jan 11, 2013 08:45 AM
Maui Built
Mar 26, 2008 09:47 PM
TurboLude97
Feb 3, 2003 11:58 AM
TurboLude97
Feb 2, 2003 01:56 PM
Homer_Simpson
Jan 23, 2002 08:39 PM
