battery relocation....
Old Mar 29, 2009 | 07:54 PM
thelate1's Avatar
Default battery relocation....
i searched the NHRA rules for this, but the date says 2007 so i'm sure it's changed. I currently run a sealed odyssey pc680 relocated to my trunk. do i need this in a moroso 74050 box? this is a street car that i sometimes drag on the weekends. i was just curious how this has to be mounted? this is in a gutted 91 Integra.
thanx.
Old Mar 29, 2009 | 08:08 PM
nonvtecallmotor's Avatar
Default Re: battery relocation....
You need to bolt it down and run a shut off switch in the back of the car. You do not need a battery box because its a sealed battery.
Old Mar 29, 2009 | 08:15 PM
srmofo's Avatar
what gauge wire do most people run?
Old Mar 29, 2009 | 09:18 PM
boostedb20z's Avatar
im running welding lead i think its 4g 1.35$ a foot
Old Mar 29, 2009 | 11:06 PM
thelate1's Avatar
cool, thanks. does it have to go through the frame, or can it be bolted down anywhere?
Old Mar 30, 2009 | 08:09 AM
fukenricen's Avatar
i have mine bolted down anywhere and i never got in trouble at the track , i also purchased one of those plastic boxes from your local stores,wallmart,canadian tire ect. for marine and it works fine and cheap
Old Mar 30, 2009 | 08:24 AM
turbo boost's Avatar
same here
Old Mar 30, 2009 | 10:15 AM
ExVtec's Avatar
2ga here.
Old Mar 30, 2009 | 10:36 AM
fukenricen's Avatar
i think i paid 15-20 bucks for that box at canadian tire also comes with tie downs and straps, just make sure all hardware is in there because people tend to move stuff around in the store, as for kill switch i used what comes on bmw's before they get pdi at the dealership, stuck it threw my rear key hole and added a guage for batt voltage
Old Mar 30, 2009 | 10:39 AM
fukenricen's Avatar
ohh another tip when doing it and it worked for me , on the negative i would strip the wire every 2feet and add a terminal to the body so you have constant ground threwout the car all the way to the front, my ground goes directly to the motor aswell
Old Mar 30, 2009 | 02:50 PM
srmofo's Avatar
damn thats a bit excessive dont ya think?
Tunerguy1989
Nov 26, 2010 09:55 AM
lude98SH
Apr 28, 2008 02:44 PM
Mr_Si-R
16
Sep 27, 2006 09:34 AM
29psiHybrid
Feb 1, 2004 09:30 PM
SilverLudeSi
Mar 12, 2002 07:58 PM
