nhra battery rules
Old Mar 12, 2002 | 10:58 AM
SilverLudeSi's Avatar
New User
Default nhra battery rules
I need to relocate my battery to my trunk to make more space in my engine bay. I know I need a battery disconnect switch, but where does this have to be mounted? Can it just be mounted in the trunk? And do I still need to run a sealed box if I am going to be using a sealed optima battery?
Old Mar 12, 2002 | 11:06 AM
b18bturbo's Avatar
Default Re: nhra battery rules (SilverLudeSi)
you will need sealed box and a cuttoff swithc. The cuttoff switch has to be externally mounted with a statement clearly indication on off
Old Mar 12, 2002 | 11:07 AM
D-Man's Avatar
A battery disconnect switch is only needed for cars that run 9.99 or better,it has to be mounted in the rear of the car on the outside so a track offical can shut it off it something happens,like a crash.
Old Mar 12, 2002 | 11:09 AM
New User
Default Re: nhra battery rules (b18bturbo)
Ok, where externally should I mount it? Under the trunk? This is a street car, so I don't want an obvious on/off switch that is hooked to my alarm.
Old Mar 12, 2002 | 11:12 AM
93LSivic's Avatar
Just so you and everyone else who reads this knows, there is a downloadable pdf format of the rule book here.
http://www.nhrasportcompact.com/2002/rules/index.html
Should answer all your race legaility issues/questions.
Old Mar 12, 2002 | 11:19 AM
D-Man's Avatar
You could mount it anywhere on a street car,dont matter,id try to find the easiest spot to reach that is out of sight,why not just mount the switch right next to the battery after its relocated.
Old Mar 12, 2002 | 11:20 AM
New User
Default Re: nhra battery rules (D-Man)
I would like to just mount it next to the battery, but it needs to be on the outside of the vehicle so that I can run at the track.
Old Mar 12, 2002 | 11:26 AM
D-Man's Avatar
How fast is your car? what class are u running it in? Pro Import?
Old Mar 12, 2002 | 11:29 AM
New User
I haven't run it yet, but you need an external cut-off switch when your battery is in the trunk, regardless of what times you are running.
Old Mar 12, 2002 | 11:35 AM
D-Man's Avatar
No,You do not need a Cut off Switch no matter where you relocate battery too,all it has to be is in Sealed Box and Vented to outside of car,only time u need Cut off switch is when u run 9.99 or quicker
Old Mar 12, 2002 | 11:41 AM
b18bturbo's Avatar
yup that is correct no need for battery cut off unless you go 9.99 and quicker. Its nice to have but not a manadotory thing.
Old Mar 12, 2002 | 01:24 PM
New User
Maybe I am misreading the rules, but I thought this means I need a cut-off switch if my battery is relocated, regardless of e.t. I would love to be wrong so that I can just put the switch in the trunk.
8:4 MASTER CUTOFF
Mandatory when battery is relocated or on any vehicle running
9.99 or quicker. An electrical power cutoff switch (one only) must
be installed on the rearmost part of each vehicle and be easily
accessible from outside the car body. This cutoff switch must be
connected to the positive side of the electrical system and must
stop all electrical functions, including magneto ignition. The off
position must be clearly indicated with the word "OFF." If switch is
"push/pull" type, "push" must be the action for shutting off the
electrical system, "pull" to turn it on. Any rods or cables used to
activate the switch must be minimum 1/8-inch diameter. Plastic or
keyed switches prohibited.
Old Mar 12, 2002 | 01:27 PM
ekb18c's Avatar
8:4 MASTER CUTOFF
ahemm re-read the rules. Its says it right there in the first sentence. Mandatory when battery is relocated or on any vehicle running 9.99 or quicker
Old Mar 12, 2002 | 01:31 PM
New User
Default Re: nhra battery rules (ekb18c)
Thanks man, but I did read the first sentence. Wouldn't the OR imply that if your car meets either of these qualifications, it needs a cut-off switch? Mandatory when battery is relocated or on any vehicle running 9.99 or quicker.
Old Mar 12, 2002 | 02:01 PM
Dee's Avatar
Dee
actually it said: A cutoff switch is Mandatory when the battery is relocated or on any vehicle running 9.99 or quicker.
If your car is slower than 9.99 and the battery is in it's STOCK postion a cutoff switch is not needed.
Old Mar 12, 2002 | 02:07 PM
New User
Default Re: nhra battery rules (drealgsr)
So, if my battery is NOT in its stock location, then I would need a cut-off switch, correct?
Old Mar 12, 2002 | 02:10 PM
D-Man's Avatar
I never had a problem with my relocated box with no Master Cut Off Switch with any tech inspector the hundred or so times ive been to a track.
Old Mar 12, 2002 | 02:13 PM
New User
Ok, great. That is what I wanted to hear. I will just put the cut-off in the trunk then. I really didnt want to deal with mounting it outside the car. Thanks D-man.
Old Mar 12, 2002 | 06:28 PM
bigTom's Avatar
dont bother with a cutoff switch in that case... u dont need it... if u would need it... it NEEDS to be outside... period... if not... just dont put one in
also... does anyone know who makes that cutoff switch with the red plastic "key"
Old Mar 12, 2002 | 07:58 PM
DeeJay's Avatar
New User
I was also thinking about putting mine in the trunk also, anyone know what i need and how to do this?
67mmlsv
Oct 1, 2013 07:18 PM
29psiHybrid
Feb 1, 2004 09:30 PM
Hondasaurs
Aug 28, 2003 08:26 AM
Rboosted717
May 9, 2003 12:25 PM
