am I crazy?
Old Aug 11, 2003 | 12:34 PM
servion's Avatar
Default am I crazy?
Well, I'm going to the track... just got my '92 cx running with the race motor in it (nothing compared to many of your race motors, but I'm trapping 117MPH in the old SI chassis with nitto 555s)
Anyway, I currently have stock suspension with stock integra axles, a quaife LSD and no traction bars. I'm going to be running some 24.5x8.5x13 M&H's (thanks to John), and I'm wondering if this is crazy of me to do? I.E., how crazy is it to run such a tire with stock axles?
Old Aug 11, 2003 | 08:51 PM
SlicksMH's Avatar
Default Re: am I crazy? (servion)
This is not crazy, I run into this ? everyday and in the early days, bump the air pressure up you have a advantage running slicks over street tires. You just have to find the sweet spot, where the slicks slip a little bit and hook up. This will take a little time but it will come fast. Good Luck and have a safe 2003 season. John@M&H
Old Aug 12, 2003 | 07:04 PM
boosted3g's Avatar
Default Re: am I crazy? (SlicksMH)
I could run 11.4s all day long on stock axels, quaiffe diff and 24.5 inch slicks. I threw the slicks in the hatch and drove to the track. It never left me sit even with countless 7k rpm launches.
Old Aug 13, 2003 | 07:44 AM
servion's Avatar
Default Re: am I crazy? (boosted3g)
Did you dump it at 7k, or slip it for the launch?
Old Aug 13, 2003 | 12:30 PM
boosted3g's Avatar
I just dumped it. The car hooked so there was no need to slip it. I could go 1.6s consistantly. I think most people that break axels in moderatly powered cars is because they lower the car too much.
Old Aug 13, 2003 | 12:38 PM
servion's Avatar
What kind of suspension setup were you running? I've currently got 100% stock suspension...
Old Aug 13, 2003 | 12:44 PM
boosted3g's Avatar
skunk2 coilovers, kyb, energy suspension bushings, comp engineering traction bars and no swaybars. If its tweaked right it will hook.
Old Aug 13, 2003 | 01:18 PM
servion's Avatar
Are the skunk2 coilovers with the drag launch springs in the rear? Can you tell me about your height settings (front and rear)?
Did you remove the swaybars for weight reduction, or some other reason?
Are the energy suspension bushings the motor-mount inserts, or some other inserts?
Thanks for elaborating on your setup for smoking 60's!!!
Old Aug 13, 2003 | 01:29 PM
boosted3g's Avatar
I had the regular coilovers. The key is setting the traction bars and the height up. I had the camber at 0 deg in the front and stock in the rear. I had about 5 degrees of positive castor and i made sure that the bars were tight and that they were equal. The car sat at stock height and nearly level. I did a 2nd gear burnout and heated them real good. I also used a 2 step rigged up on my cruise control clutch switch. Thats all there is to it.
Old Aug 13, 2003 | 01:58 PM
servion's Avatar
Awesome, thanks!
Why did you remove the sway bars?
Old Aug 13, 2003 | 02:25 PM
boosted3g's Avatar
You dont need them if you are drag racing. If a rwd v8 car they have been known to help the weight transfew to the back tires but when i took them off my car i didnt even notice they were gone. The car handled the same and launched the same. The only difference was i was 25 lbs lightler.
Old Aug 13, 2003 | 02:45 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
i went 10.9x 5 times, 11.0 3 times, and numerous low 11's on stock axles, stock diff gsr tranny, and 25x8x13 slicks. No problems, dumping the clutch at 6k
Old Aug 14, 2003 | 10:29 AM
servion's Avatar
Default Re: am I crazy? (SIXTYdashONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">i went 10.9x 5 times, 11.0 3 times, and numerous low 11's on stock axles, stock diff gsr tranny, and 25x8x13 slicks. No problems, dumping the clutch at 6k</TD></TR></TABLE>
Congrats on some great times!
What sort of suspension setup are you running, if you don't mind disclosing?
Old Aug 14, 2003 | 03:16 PM
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">
What sort of suspension setup are you running, if you don't mind disclosing?</TD></TR></TABLE>
Thanks man.. That 10.92 was on Stock Struts and Neuspeed race srings.
Old Aug 14, 2003 | 03:52 PM
servion's Avatar
What kind of fitment issues did you have with those slicks and the neuspeed race springs?
Old Aug 14, 2003 | 04:03 PM
HT's Biggest Loser
Im sorry, i should have elaborated a little.. I had regular skunk2 coilovers in the front, and neuspeed race in the rear. They have since been upgrated to skunk2 race coilovers in the rear, Still stock struts tho
HamiltonRex
May 28, 2006 08:47 AM
LSVTEC 91 Civic
Apr 2, 2005 07:17 PM
gSr_jB
Feb 25, 2005 08:19 PM
jdmekcivic2eg
Apr 15, 2004 07:25 PM
Cory man
Jul 26, 2002 08:56 AM
