"Alternator"
Old Nov 22, 2011 | 07:40 AM
jtechbluelx's Avatar
Default "Alternator"
Need help what alternator are you guys with high HP using and any info where i can get my hands on one....thanks
any info would be highly appreciated
Old Nov 22, 2011 | 07:54 AM
turbo-2nr's Avatar
Default Re: "Alternator"
we just use the stock one
Old Nov 22, 2011 | 08:01 AM
turbohatch96y7's Avatar
Do you know what an alternator does??
Old Nov 22, 2011 | 08:43 AM
The regulator or alternator itself must have had a fault and happened to give out at that time. Bigger alternators are usually used for more amps not voltage since our cars run off 12v. Unless you have a large load.
Old Nov 22, 2011 | 09:12 AM
JJsMotorsports's Avatar
I made 963whp with oem Denso Alternator, but i did buy brand new and it did help stablize my voltage thru-out my runs.
Old Nov 22, 2011 | 09:28 AM
thanks for the info guys
Old Nov 22, 2011 | 02:19 PM
FRernesto's Avatar
Get a flux capacitor! Lol
Old Nov 22, 2011 | 02:23 PM
Dynamic Performance Racing's Avatar
Stock gsr here lol!!!
Old Nov 22, 2011 | 02:26 PM
SR20S13's Avatar
none
dschenke's Avatar
curious does anyone run a deep cycle battery and just charge between runs.
if car is full drag why even have an alternator
Old Nov 22, 2011 | 02:42 PM
dam im looking at a ghost mini were the fluck have u been lol..
Old Nov 22, 2011 | 03:27 PM
SPOOLINmatt's Avatar
ive had my share of ALT problems this year and last. Go get a OEM honda reman at your local honda dealer and don't look back.
Old Nov 22, 2011 | 04:43 PM
ashtons300zx's Avatar
Im sure some do but everyone that i know personally who has tried to do that has had issues. Fuel pumps and ignition systems like to see at least 13.5-14.0 volts and your not going to get that from just a battery. Especially cars with a lot of electronics on it, twin fuel pumps, electric water pump, electric fan, and so on are probably drawing close to 75-80amps off the batter when everything is on at the same time. So you gotta think about that. The larger the amp draw the more its going to bring down the voltage as well.
Your fuel pumps especially will not be able to function correctly.
Why bother without running one, Alt and bracket are probably 15-20 lbs at the most and probably only take 2-3hp under full load to turn them. So why not just run one. Much safer.
The higher amp rating alt you can get as well should help and wont work as hard to keep up with everything. I know with all the stuff on my car on at the same time my poor 70 amp alt was having a hard time keeping up and keeping the battery charged especially with the headlights other stuff on. So im upgrading to a newer Sentra 100 amp alt and that should do the trick and not have issues.
Old Nov 22, 2011 | 04:50 PM
dschenke's Avatar
hmm a deep cell will hold charge longer too so i mean i dont know how many volts it would go down after a burnout and 10 second run. my freinds shop alcohol dragster runs a odyssey battery no alt. but then again it basiclly only powers the datalogger and all gauges, everything else is mechanical, no water pump, mech. alcohol injection. So i can see where u are coming from
Old Nov 22, 2011 | 04:57 PM
FRernesto's Avatar
Hey brother how are and everyone? I'm good half way across the country now.
Old Nov 22, 2011 | 10:42 PM
dueyx99's Avatar
alts are useless on drag setup when you can run 16volt batteries
Old Nov 22, 2011 | 11:01 PM
uglyasscivic's Avatar
I am changing to a 16v but right now I have a 175amp alternator from Boss. It helped a bunch for my setup.
Old Nov 23, 2011 | 03:22 AM
pues que se joda yo boy a poner uno stock tambien lol.
Old Nov 23, 2011 | 03:24 AM
dam my dude .......every one its good out here....when are u coming around here mini?
Old Nov 23, 2011 | 03:25 AM
thanks for all the good info guys.
Old Nov 23, 2011 | 07:17 AM
vtekthis's Avatar
i tried OEM, aftermarket, aftermarket rewound, custom wound ect
only way to get "stable" voltage is go with a good 16 volt setup...
Old Nov 23, 2011 | 09:21 AM
doug118's Avatar
Honda Odyssey alt is 140amps. That should help keep the voltage up, along with a good battery
Spencerk10
Sep 12, 2015 11:55 PM
AllMotorRandy
Sep 3, 2005 01:35 PM
JBk24crx
10
Nov 15, 2003 11:14 PM
