aem ems boost controll ?
Old Apr 10, 2007 | 06:01 PM
ALL IMPORT's Avatar
Default aem ems boost controll ?
after my last event having my greddy boost controller costing me a race, decided to run the low/high boost through the ecu off of the vss.
we got some good progress so far.
using the turboxs solenoid.
got the gain map around 50% give or take some to keep the boost holding in the right spot..
the car pulls very nice in 3rd on the dyno but in forth it seems as if the solinoid is pulsating a little making the rpms fumble a little but the car still pulls making power. the boost is holding around 30psi nicely. inthe other gain setting the graphs are very smooth & almost straight across as aem said they need to be.
so my question is have any pf u had this problem? what did u do ?
& is thier any tricks that u car 2 share?
Old Apr 10, 2007 | 10:14 PM
wHOAlly's Avatar
Default Re: aem ems boost controll ? (ALL IMPORT)
i dont understand the question?
email me your cal and i can take a look at it...
htran@aempower.com
Old Apr 10, 2007 | 10:18 PM
1FSTHATCH's Avatar
Im using the AEM solonoid but im sure your having the same issues as i was at first..When you go under the boost control setting in your map, go to advanced boost control and theres a frequency setting for your solonoid activation..If you not using the proper frequency it can cause boost fluctuation with all the sensors running on the same freqency..I change mine to 30mhz i believe and had no more issues with it..Try that let and see how it works..
Old Apr 11, 2007 | 03:04 AM
ALL IMPORT's Avatar
Default Re: aem ems boost controll ? (1FSTHATCH)
31hz is where were at now. thats what it functhion at best
firstclassjdm
Apr 11, 2005 07:05 PM
dunkd
Jan 28, 2005 10:40 AM
Aug 19, 2002 06:50 PM
symba
Jul 15, 2002 05:29 PM
PyroVTEC
Jun 7, 2002 11:51 AM
