22" slick problem
Old Jun 6, 2010 | 04:31 PM
jordanitr's Avatar
Default 22" slick problem
I went to the track yesterday and did a few runs on street tires, then a bunch on my 22" slicks.
The Slick size is 22x8x15 on a 15x6 ITR wheels, this is how I bought them.
My car is 00 type R, only mods are I-H-E.
On street tires, I ran a
2.305-60' with a 14.4 at 97.5 1/4, 3 runs
with slicks, I ran a
2.160's-60' and the 1/4 still all a 14.5 at 95 and this was with 6 runs.
So my Q is how is that possible? Better 60' but with worse 1/4 time.
Im kinda stumped any help would be great. thanks
Old Jun 6, 2010 | 04:50 PM
BrowNKiD's Avatar
Default Re: 22" slick problem
what was your tire pressure?
Old Jun 6, 2010 | 05:30 PM
Gunmetal_B20_Hatch's Avatar
2.1 60ft on slicks...
someone needs some more seat time.
Old Jun 6, 2010 | 05:33 PM
xtrafastcivic's Avatar
is the clutch slipping?
Old Jun 6, 2010 | 05:35 PM
wilham320's Avatar
gearing could be an issue too... what was the difference in gear/rpm when you crossed the traps between the two different tire sizes?
Old Jun 6, 2010 | 07:37 PM
jordanitr's Avatar
I tried tire pressure on all 6 runs starting at 18 working my way down to 12psi, the lower the tire/p the slower trap speed.
Clutch is new. As for the gearing, its stock ITR tranny with 4.7 FD.
Do you think its the wheel on slick size that could be the problem? 8" slick on a 6" wheel.
It looks like this sitting on the wheel \| |/
Old Jun 6, 2010 | 09:44 PM
OMG B16's Avatar
Start your tire pressure at 9psi and go down from there. Are you sure your not hitting the rev limit before the traps?
Old Jun 7, 2010 | 01:55 AM
vivid 02's Avatar
10psi. Good burnout let the slicks pull you thru and out the burnout box.
Try launching a diff RPM's. Start at around 7k rpm. based on that work your way up or down. If bogs, you need more rpm. If too much spin, lower rpm.
Old Jun 7, 2010 | 11:20 AM
still_slow's Avatar
I always ran 14psi in my 22" slicks consistent 1.8x 60's I would say its all in your launch try launching higher.
Old Jun 7, 2010 | 01:07 PM
E85B18's Avatar
x2. Try higher rpm and 10psi
Old Jun 7, 2010 | 01:26 PM
gringotegra's Avatar
Let me drive it jordan
Old Jun 7, 2010 | 02:35 PM
OMG B16's Avatar
My buddys car:
http://www.youtube.com/watch?v=_reUA-Ama1U
22" slicks, 7/8 psi in the tires on stock gsr wheels = 1.66 60ft's. These slicks were a year+ old also. Dont be scared to lower the tire pressure.
Old Jun 7, 2010 | 07:52 PM
jordanitr's Avatar
I will, but i think its to slow for you.. I dont want you falling asleep behind the wheel of my precious.
b20vtech
Feb 9, 2009 04:18 PM
JoeSiR
Jun 3, 2003 05:46 PM
Cyber ITR
Apr 21, 2003 04:54 PM
Zeus Zore
Feb 1, 2003 11:50 PM
