Great 60', low MPH...why??
I remarked that each time that I've got great 60 feets time with my slicks my mph is lower than with my street tire. I just want to know why??
Best MPH with slicks is 98.8MPH and with street tire 99.5MPH with a 2.2 60'.
Thanks
Thanks
Re: Great 60', low MPH...why?? (JV)
20X8X14 MT but it seems that every car on street tire have better MPH (but lower ET)with the same set-up compared to slicks.
Re: Great 60', low MPH...why?? (JoeSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeSiR »</TD></TR><TR><TD CLASS="quote">I remarked that each time that I've got great 60 feets time with my slicks my mph is lower than with my street tire. I just want to know why??
Thanks</TD></TR></TABLE>
This is the way it is... you car will build a faster trap speed with Tire Spin... 60' will effect your ET not your MPH... with better grip on the slicks your wheels are spinning less... so lower MPH!
1 Post
Re: Great 60', low MPH...why?? (DVSshoeco)
Start the 1\4mi in 2nd gear and tell me what your mph is....it's going to be way higher. Tire Spin puts you in a higher gear earlier, which gears your out to be a higher mph...just takes longer to get there.
I am a bad person
Re: Great 60', low MPH...why?? (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Start the 1\4mi in 2nd gear and tell me what your mph is....it's going to be way higher. Tire Spin puts you in a higher gear earlier, which gears your out to be a higher mph...just takes longer to get there.</TD></TR></TABLE>
I will try launching the car in 2nd on street tires when i get back out. I was given that advice by a big dog racer. anyone ever try it??I have to break the street tire record somehow. I have seen lance from Hp do it at moroso before and run a low 9.
The 20" slicks are about 2-3" shorter then the factory or +1/+2 wheel sizes. They just can't pull the MPH's.So, in theory moving up to a 22" slick will recover your MPH. Just make sure you have enough HP as to not bog them on the line.
Modified by Civic_95_Si at 3:06 AM 6/4/2003
Cyber ITR
04-21-2003 04:54 PM
