Machine buffing issue
I'm trying to polish my car using a high speed buffer and even at low speeds the polish I'm using keeps drying quickly. I'm using Griots Machine Polishes so I'm sure it's me and not the product. lol
Any help would be appreciated.
What pad are you using? If you're not using an adequete cutting pad for the clear coats conditions, this can happen.
Spread the product evenly and heat it evenly. Some paints, especially water based, tend to have the product "stick" to the clearcoat even at moderate RPM's.
But Honda doesn't use this, so my guess will be that you need to go with a more aggressive pad, or your technique is incorrect.
I know this may sound stupid, but are you doing it in the direct sunlight? Polishes and like products are meant to be applied in shade. It is near impossible to use a cutting polish or compound and break down the minerals/chemicals if it is the direct sunlight because it dries too quickly.
What type of polishes are you using?
almost all poorboys products including paste wax can be used in direct sunlight. nattys blue is one the best waxes i have used and i make it an effort to put the rig in the sun when im going to apply the wax.
I figured it out today.......turns out I was using the wrong kind of pad. I went and got a pad with more cut and it seemed to help out alot. That and I just mist some water on the pad every once in awhile.
all stock
21
Apr 28, 2003 03:55 PM
