Synapse Missing Link ML001B
Old Jan 14, 2004 | 01:18 PM
Boofster's Avatar
Default Synapse Missing Link ML001B
http://www.synapseengineering.com
Selling a Brand New Missing Link. This is the ML001B-Spec, the newest design available with an improved internal mechanism for faster response time. If your car runs a Turbo, this will eliminate all of the check engine lights that are turned on from the Map Sensor picking up boost. The Missing Link is a CNC Aluminum component that will bolt on directly to your throttle body. Also, installation will get rid of the Fish Tank valves that come with turbo kits such as Rev Hard and Drag.
This Missing Link Installs in 5 Minutes and will produce instant results! Designed to work in Boost Conditions up to 40 psi! Works on OBD-1 and OBD-2 Computers!
The ML-001B Has been Engineered for the Following Turbocharged Vehicles:
1994 – 2001 Acura Integra B18 series engine
1992 – 2002 Honda Civic Z16/B16/D16 series engine
1994 – 2002 Honda Accord
1997 – 2002 Honda Prelude H22 series engine
1999 – 2002 Honda S2000
The Missing Link is a complete Bolt On Part which comes with:
Mounting Hardware & O Rings
Longer Screws
Installation Instructions
$60 shipped
Old Jan 14, 2004 | 08:52 PM
94sohcEx's Avatar
Default Re: Synapse Missing Link ML001B (Boofster)
ive got a 94 ex with a z6...i believe that requires the firewall mounted missing link rather than the throttle body version if i am correct...do you have those available?
Old Jan 15, 2004 | 06:53 AM
Boofster's Avatar
Default Re: Synapse Missing Link ML001B (94sohcEx)
Well, your car is on the list for this model. I had a Z6 a while back and I don't remember where the MAP sensor was. Look at your engine and see if you can find a little black sensor that says MAP on it. I am pretty sure it has to be on the throttle body. Manifold Air Pressure right?
Look at this pic of a D16Z6 I dug out, it's the plug on top of the TB:
Old Feb 5, 2004 | 07:55 AM
Boofster's Avatar
Buy me!
ROCAFELLA2049
Jun 29, 2006 09:24 PM
Treblarefils
Feb 23, 2005 11:26 AM
integraracer94
May 23, 2002 04:19 PM
Turbohatch
Jul 2, 2001 10:35 PM
