Hondata + High BOOST!!
Old Oct 16, 2003 | 09:08 AM
TurbodCX's Avatar
Default Hondata + High BOOST!!
ok guys i need to know what the hondata system will do if i boost over the 28.5psi limit in the romeditor?
I have went in and unchecked the box that say enable boost cut,
so i am wondering if i can run 30psi+on this setup.
I am thinking that the system will just carry the values from the 28 psi column on out to the 30+ psi values.
And just so you are wondering i want to run this high of boost,because i am ony 8:1 compression and i am currently buying a Large FMIC and a 70mm TB(thanks to boosted hybrid!) adn i want to crank the boost up to make 430whp out of my D-series so i can run 11's on BFG's next year.
Does anyone know?
Thanks
Brian
Old Oct 16, 2003 | 09:10 AM
TurbodCX's Avatar
Default Re: Hondata + High BOOST!! (TurbodCX)
soory mods you can delete, wrong forum!
BLWNB16A@11psi
Jun 22, 2005 08:27 PM
btrim23
Feb 26, 2005 02:32 PM
BlackThorN
Dec 21, 2003 12:51 AM
TurbodCX
Oct 16, 2003 11:23 AM
5thgencivic
Sep 17, 2003 06:41 PM
