HKS EVC silver boost controller New In the Box!
New User
The EVC IV - Silver is a user-friendly, full-featured digital electronic boost controller that utilizes a precision “closed-loop” boost regulating stepping motor. Stepping motors are used because they can handle higher boost levels and are quicker to react to various conditions, thus offering quicker boost response and higher stable boost levels throughout each gear. The HKS EVC IV - Silver can correct the signal to the wastegate several times each second, thus allowing a more rapid boost rise without overboosting. A built-in “Fuzzy Logic” program will learn the base boost curve and optimizes it for maximum response and stable boost. For instances where “Fuzzy Logic” is not applicable, it can be bypassed during initial setup. Via an illuminated **** on the headunit, the EVC IV - Silver is adjustable up to 2.5bar (36.25psi) of boost pressure and incorporates a white-colored backlit real time digital boost and vacuum display for precise boost calibration and monitoring. Another new feature on the EVC IV - Silver is a peak-boost level hold function that allows for easy reference of peak boost levels attained. A 1-Touch “High” and “Low” boost level presets allow for multiple settings to accommodate for varying power needs. For extra boost, the scramble boost feature will add a users specified amount of boost over the current boost setting for a preset duration between 1-30 seconds. An optional remote scramble boost trigger is available to supplement the trigger button on the headunit for Scramble Boost activation. A built-in visual and audible overboost warning feature will revert boost levels to baseline if boost levels exceed the warning level entered by the user. To prevent losing all valuable data and presets, each EVC has flash memory to retain all settings and presets if power is ever removed from the unit.
Located in Los Angeles, I'm heading out to work now, but I will send pics to those interested tonight. Email me at hunngweilow@hotmail.com for pics
Price 300firm+shipping and insurance, thanks
1A4
02-02-2007 12:01 PM
spork
01-16-2003 01:39 PM
