D16z6 sleeved spun bearing partout
Maybe drove 1 mile after oil psi dropped. Bearing was still on scratched.
prices are obo, pickup chicago il , if u want shipping money order only or maybe paypal
Selling a d16z6 engine that spun a rod bearing
Block -10k miles on build before it spun a bearing
inlinepro sleeved
Arias forged 76mm pistons
Eagle rods (needs new rods)
d16y8 oem crank (needs new crank)
Block was line honed and bored to 76mm .0044 p2w on the pistons (some scrapes against the pistons and cylinder walls very minor)
needs new oil pump
new oil pan with turbo fitting for oil return
(the bearing was still on the rod, so it went for maybe 1 mile before turn off. turned it off pretty quick)
Head
D16zc head
zc camshaft
zex springs
76mm cometic gasket
d16z6 distributor (newer)
Gates blue timing belt
water pump
300$ for the head, its 5 angled valve jobed and has zex springs, so its super easy to put in a bigger camshaft, zc camshaft is like 60-80$ if you want to sell it and get some stage 3 camshaft
600$ for the block with arias pistons. Id have a shop hone it very minimally. too much and ur engines gona lose compresssion and die. flexible on the price if ur driving from far away
Turbo setup
cast iron t3 manifold - 40$
5 bolt downpipe -60$
CC stage 5 clutch (10k miles)
8lb chromoly flywheel (10k miles)
240$ for both
Block
Re: D16z6 sleeved spun bearing partout
yeah but im selling it with the shell its wired up i aint cutting up and pulling it out
im gona take apart the head/block/tranny soon and post photos more of them
interested in this. PM me
Fuel
Hondata s300 v2 with boostbygear with noost solenoid -500$
Hondata is tuned for this 1000cc injectors and 4 bar map it a/f always 12 under wot boost real good tune
1000cc injector dynamics redtop fuel injectors- 320$
4 bar map sensor no brand - 30$
the WG and DP as well.
Fuel
inlinepro sleeved
needs new oil pump
Head
D16zc head
zc camshaft
zex springs
76mm cometic gasket
water pump
250$ for the block with arias pistons. Id have a shop hone it very minimally. too much and ur engines gona lose compresssion and die. flexible on the price if ur driving from far away
need block gone sold everything almost from the part out-- 250$$
Turbo setup
Block
