Classic Hondas All Pre-1988 Hondas.
CLUTCH!!!
Old Feb 12, 2008 | 02:27 PM
pootelytoot's Avatar
Default CLUTCH!!!
my clutch is completly messed up. i have a 94 civic ex and when i push the clutch in it doesnt have and tension on it until it almost hits the floor!!! it happens when i start the car and i have to ware the clutch in in-order to get it in gear. any ideas on what to do?
button
Old Feb 12, 2008 | 04:05 PM
E-AT_me's Avatar
Default Re: CLUTCH!!! (pootelytoot)
first, post in the right forum. second, either you are low on fluid, or your slave cylinder or master cylinder needs to be replaced. is there fluid on either? aka, are any seals leaking?
Old Feb 12, 2008 | 04:20 PM
Default Re: CLUTCH!!! (E-AT_me)
hey man it was my brake fluid! that **** was completly empty! thanks though
Old Feb 12, 2008 | 04:28 PM
E-AT_me's Avatar
it doesn't go missing for nothing! check for leaks!!!
Old Feb 13, 2008 | 05:42 AM
86punishment's Avatar
Wait?.. the clutch was messed up cuz he didn't have brake fluid? wtf? could someone explain this to me ... hmmm i guess this new-fangled ship just werks funne
Old Feb 13, 2008 | 08:16 AM
E-AT_me's Avatar
Default Re: CLUTCH!!! (86punishment)
newer hondas have "hydraulic" clutches which the fluid would be brake fluid.
Old Feb 14, 2008 | 05:58 AM
ya i know, i was just messing cuz he said brake fluid but it dont matter sorry if you thought i was being critical
but as for a question...
to get this post on topic of pre 88 clutches,...
My 86 clutch wont fully disengage, it starts grabbing about 1/3 the way from the floor and is fully engaged 1/4 from the top ..
so from the floor to where it starts engaging it should be released but it feels like it's feathering... causing me to have to sncronize my shifting and shut the motor off to go from 1st to reverse or vise versa it makes shifting a pain and unsafe
I had my neighbor push in the chutch while i watched the operatin and the arm that pushes on the throwout bearing keeps moving throught the range of the pedal.... even to the floor i adjusted the free play down to nearly nothing to get the most out of the pedal but it doesn't seem to make any difference and is getting worse as i drive it..
any ideas??
Old Feb 14, 2008 | 07:20 AM
E-AT_me's Avatar
time for a new cable. it's probably stretching.. they do break.. then it is fun..
Old Feb 14, 2008 | 07:59 AM
at first i thought it would have been a cable,
but the throwout ARM keeps moving after the "disengagement" point
wereas if it were the cable would't it stop where it was feathering at?...
does that make sense?
Old Feb 15, 2008 | 11:42 AM
is there anything else this could be?
Old Feb 15, 2008 | 11:58 AM
E-AT_me's Avatar
makes sense. maybe pressure plate is bad? or something with the throwout bearing.. our clutch assemblies are extremely primitive, so it can't be too hard to figure it out.
Old Feb 25, 2008 | 07:41 AM
no longer a big issue its no longer tagged or insured..
got an 08... i guess this is perfect timing now i can start to re-build the 3rd gen
thanx for the help
Toonz18
Feb 26, 2018 11:54 PM
ray.riddler92
May 4, 2011 01:00 PM
mugenspoongsr
Aug 2, 2006 03:14 PM
sniperslayer
17
Nov 5, 2005 06:29 PM
Malice
Feb 4, 2002 08:16 AM
