Classic Hondas All Pre-1988 Hondas.
85' Wagovan run issues
Old Sep 11, 2010 | 09:35 PM
dirtygherkin's Avatar
Icon6 85' Wagovan run issues
Hopefully im posting in the right section. I'm a vw/audi tech and way out of my element here so bare with me. I just got done doing a head gasket on my buddy's 85' wagovan bone stock d15. Anyway leading up to the head gasket blow was incremental lessening of power. The Issue now seems to be "bogging" past say 3000 rpm it appears that the secondary on the carb never opens which would definitely explain that. The port on the front of the carb appears to not draw enough vac@w.o.t. to pull it open Ive verified the linkage is functioning and the lines are in good condition. I even probed the port with a pick tool assuming it was blocked but no dice.
Any input or suggestions would be greatly appreciated
Old Sep 12, 2010 | 08:49 AM
JAF Mugen Power's Avatar
Default Re: 85' Wagovan run issues
I would suggest a new fuel filter, checking your timing, and adjust it with the distributor to see if it doesn't clear up. THEN, consider a carb rebuild. Good luck.
Leviatard
Oct 29, 2015 08:33 PM
fsl
Classic Hondas
Jul 17, 2012 06:50 PM
z0om
Aug 28, 2008 04:12 PM
superfuji57
Jun 27, 2004 08:27 PM
paybac4223
Mar 22, 2004 06:36 PM
