1986 Honda CRX "Wont Shift"
I have a 86 Crx, that wont shift.
I can shift when the engine is not running, but with the engine running it's very hard to change the gear's and they grind, I don't know what's wrong!
Has anyone had this problem before in the passed, does anyone have any suggestions.
Re: 1986 Honda CRX "Wont Shift"
i bet the clutch cable just needs to be adjusted. look at where the clutch cable is on the front of the tranny, the bracket there is adjustable, i have no doubt that its just too loose.
it doesnt matter if you havent adjusted the clutch just do it its not even hard , just a 10mm wrench and you loosen one side and tighten the other. mabey the previous owner replaced the clutch and forgot to clamp it down with the two nuts and it just loosened itself.
Last edited by SRZsmack; 06-03-2009 at 01:28 PM. Reason: explanation with less posts.
until it feels good to you but try not to overtighten. its best if you have two people one in the car trying out the clutch and the other adjusting it. make sure no one is standing in front of the car while you try to turn it on cuz the car might jump at ya.
Wow your smart, thanks man your a lifesaver.
The other possible problem is that the bracket on the top of the pedal assembly broke. Easiest way to see about this is to look at where the cable goes into the firewall. If the rubber seals has been pulled into the car the bracket on the pedal ***. is most likely broken.
Anyway, check it out and let us know.
RyanIrwin90CRX
11-14-2013 06:44 AM
peiku
12-31-2005 11:05 AM
