WTF is wrong??
Old Feb 10, 2005 | 02:42 PM
brianb123's Avatar
Default WTF is wrong??
A few weeks ago, I disconnected my amp, and forgot the disconnect the battery before hand. Now, something major is wrong with my audio system. First, I thought it was the headunit, but I just bought a Pioneer DEH-P3600 and this headunit doesn't work either. Some more info is when I put my stock headunit back in (6 disc in dash changer,) you can hear the changer clicking and checking for cds, so I'm guessing there is power. The wires I got from Circuit City to hook up my new headunit are "smart wires" and everything is just plug and play. If anyone has any ideas of whats wrong please speak up. Thanks.
Old Feb 10, 2005 | 04:46 PM
mustbenu's Avatar
Default Re: WTF is wrong?? (brianb123)
check all your fuses first...
Old Feb 10, 2005 | 04:47 PM
mustbenu's Avatar
Default Re: WTF is wrong?? (mustbenu)
some headunits have internal fuses
Old Feb 10, 2005 | 06:25 PM
brianb123's Avatar
all the fuses ive checked so far appear to be fine (the one under the dashboard, and the one in the back of the headunit.) I dont know of anymore. If you have any advice please respond. Thanks.
Old Feb 10, 2005 | 07:30 PM
showtime23's Avatar
Now, something major is wrong with my audio system--wuts wrong?
Old Feb 11, 2005 | 07:39 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brianb123 &raquo;</TD></TR><TR><TD CLASS="quote">all the fuses ive checked so far appear to be fine (the one under the dashboard, and the one in the back of the headunit.) I dont know of anymore. If you have any advice please respond. Thanks.</TD></TR></TABLE>Did you check the 7.5A fuse in the engine bay fusebox?
What was the amp running?
Have you hooked up the amp again?
Need this info. 94
Old Feb 11, 2005 | 11:24 AM
brianb123's Avatar
Default Re: WTF is wrong?? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Did you check the 7.5A fuse in the engine bay fusebox?
Need this info. 94</TD></TR></TABLE>
1. no
2. 40 watts@4ohms
3. Havent hooked it up again
Thanks
Old Feb 11, 2005 | 06:59 PM
brianb123's Avatar
niiiice! my stereo is finally, after a month of silence, working again! After closer examination of the fuse box under the steering wheel, there is a fuse that says "radio acc," its a 7.5 fuse and was blown to ****, so as soon as I replaced this its worked ever since! Thanks everyone!
Old Feb 18, 2005 | 02:58 PM
H22HondaCRX's Avatar
Modified by H22HondaCRX at 6:30 PM 2/19/2005
Old Feb 18, 2005 | 10:42 PM
CooBlueDAB's Avatar
Default Re: WTF is wrong?? (H22HondaCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22HondaCRX &raquo;</TD></TR><TR><TD CLASS="quote">You should check all fuses for the problems with the amp. However the problems with the headunit, in order for it to work, you first have to take it out of the box, then install the headunit properly, then press the on button. Good Luck</TD></TR></TABLE>
that is two threads you brought back from the dead after they were solved.... what is wrong with you?
Old Feb 24, 2005 | 10:45 PM
Mr TyGuy's Avatar
Default Re: WTF is wrong?? (CooBlueDAB)
hahahahahahahahah dude ur killin me. im new and everything but thats awesome
lPat
Dec 9, 2007 04:51 PM
sohc_coupe24
Aug 3, 2006 07:43 PM
YEABOY
Audio / Security / Video
11
Feb 8, 2006 07:38 AM
brianb123
Feb 10, 2005 10:00 PM
Sarren
Aug 7, 2004 12:50 PM
