WIRING HELP
Old Mar 8, 2005 | 03:31 PM
D for D series's Avatar
Default WIRING HELP WITH PICS UPDATED
i have normal amp wiring going through my car already, but i just got a audiobahn powered badd tube, everything is differend on the amp need major help, also am i able to get the amp off the tube and hook up a better amp
Power and ground and stuff
Modified by ZeroSkate9119 at 4:56 PM 3/8/2005
Old Mar 8, 2005 | 04:28 PM
B18C_EJ8's Avatar
Ummm, yeah... You need the plug that goes into the bass tube. And although I'm sure it's possible to take the amp out of the tube and replace it with another one, it won't be worth it and you'd be wasting your time.
Old Mar 8, 2005 | 06:21 PM
civic_speed99's Avatar
Where did you get it. My friend had that same sub and his came with the power harness. All you have to do is get that and hook your normal amp wiring into it.
Old Mar 8, 2005 | 06:31 PM
Dougs96SI's Avatar
Default Re: (civic_speed99)
If worse comes to worse you can cut off the outer plastic and hard wire it in there. Who needs the plug anyway?
Old Mar 8, 2005 | 08:01 PM
Default Re: (Dougs96SI)
thanks for the tips, o got it from a friend
Old Mar 8, 2005 | 08:57 PM
Default Re: (ZeroSkate9119)
hope it works for ya
Old Mar 9, 2005 | 12:24 PM
thanks
Chriskemp
Audio / Security / Video
Sep 29, 2013 09:58 AM
westminsterCA
May 6, 2007 09:27 PM
1bar
Dec 18, 2005 08:06 AM
Mazzazx51
May 19, 2004 05:55 AM
loki2323
Nov 19, 2002 09:34 AM
