need help with amp wiring
Old May 6, 2007 | 08:37 PM
westminsterCA's Avatar
Default need help with amp wiring
i need major help on my amp wiring. its a kenwood kac 8452 and im trying to run it to two 12inch subs. i dont know jack so any help would be appreciate. i have all the wires but no knowledge of how to hook them up. i got the basics stuff done which is the battery and ground. my rca wires are white a blue and i dont know which port it goes. i have a orange wire that suppose to connect the amp to the deck. where is the wire suppose to connect to on the deck? and i also need help on the wiring from the amp to the subs. Any information would really help out dont have anymore money to go to get it done professionally. if possible pictures would really be helpful. thanks
Old May 6, 2007 | 09:27 PM
fcm's Avatar
fcm
Old Fart
Default Re: need help with amp wiring (westminsterCA)
Do you not have the manual?
http://inform2.kenwoodusa.com/manuals/KAC8452.pdf you will see you can't use the whole amp as a sub amp because only 2 of the 4 channels have a low pass filter, if the HU you have has a sub output W/ x-over built in, then you could.
If not, all you can use is the B ch for the subs. 94
z06eateR
Audio / Security / Video
Jul 20, 2010 01:41 PM
alispoon
19
Sep 6, 2008 05:07 PM
D for D series
Mar 9, 2005 12:24 PM
newf
Sep 1, 2004 12:17 PM
Starrman85
Apr 15, 2003 04:24 PM
