wiring harness problem
Old Oct 26, 2003 | 07:16 PM
eg ferio's Avatar
Default wiring harness problem
ever since my car was stolen my red igntion wire does not work so i had to wire up the ignition wire to the yellow battery wire but the thing is the radio stays on no matter what unless i remove the face....can i run the ignition wire to the cigarette lighter in order for my radio to function only with the ignition is on? also for some reason my door panel speakers dont work!!all the wiring is where it should be and evrything is well connected.is there anything else i should look for to find out why arent they working?
Old Oct 26, 2003 | 09:33 PM
djurbang's Avatar
Default Re: wiring harness problem (eg ferio)
correct me if i'm wrong but the yellow wire is the ignition wire and the red wire is the accessory.. the only thing i can think of for your speakers if all the connections are perfect, is if somehow you shorted them out rewiring stuff.. your problem confuses me
Old Oct 26, 2003 | 10:06 PM
eg ferio's Avatar
Default Re: wiring harness problem (djurbang)
ummm im pretty sure yellow is battery,red is ignition,black is ground...etc...please correct me if im wrong but im pretty sure thats how it is,but thanx anyways
Old Oct 26, 2003 | 10:59 PM
djurbang's Avatar
battery and ignition wires are the same thing, red is accessory/12V constant. if you hook your battery/ignition wire to the constant, your receiver will be on 24/7 until you actually turn it off, is this what's happening? for future reference orange is illumination, black is ground, and usually the blue and white is the remote lead for amps.
Old Oct 26, 2003 | 11:19 PM
TurboBumblBee's Avatar
does your clock work? i would def check all the fuses.. there are a fuses under the dash as well as under the hood..
Old Oct 27, 2003 | 06:47 AM
eg ferio's Avatar
Default Re: wiring harness problem (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">does your clock work? i would def check all the fuses.. there are a fuses under the dash as well as under the hood.. </TD></TR></TABLE> is their a fuse for the door panel speakers? and yes the clock does work
Old Oct 27, 2003 | 10:46 AM
Jagan'92's Avatar
Yes you can run the radio from the cigarette lighter - red wire so it only turns on with the ignition.
try pulling those speakers out and verify they work at all - put some kind of signal into them with a walkman or whatever. then do the same thing with the original wires - put the walkman in place fo the radio and the speakers back in the doors to test the wire between radio and door. if they still work it might be the output of the radio that's out.
Old Oct 27, 2003 | 04:19 PM
eg ferio's Avatar
thanx for the info
wwolf771177
Feb 4, 2014 02:25 PM
tyrone2982
Audio / Security / Video
Jan 6, 2006 08:07 PM
4runner
Jun 10, 2005 03:36 AM
BodyKits NW
Aug 9, 2003 12:38 PM
MonkeyMagic
Jan 29, 2003 06:02 PM
