which wires? killswitch question
Old Jun 24, 2007 | 12:12 PM
BJA86's Avatar
Default which wires? killswitch question
ok so heres my problem the wires i need to get to where the connector is so i can verify the fuel pump wire is actually under the metal peice like the peice that the front seats are attached to and i cant pull em out but i can get to the wires i a diff place so there are 2 yellow wires with stripe
yellow /black stripe and yellow/green stripe ...whjich would it be ?
Old Jun 24, 2007 | 12:54 PM
94_DC4's Avatar
Default Re: which wires? killswitch question (BJA86)
You will need to use a digital multi meter to test the wires. The fuel pump wire will give 12v when the ignition is turned on. And you forgot to give us the MM&Y of the car.
Old Jun 24, 2007 | 01:05 PM
BJA86's Avatar
Default Re: which wires? killswitch question (94_DC4)
99 si ...i have a volt meter,so i would have to cut the wire in order to test it because i cannot get to the plastic connector as shown in the picture ..i dont even see one
yell/blue
yell/green
yell/black
Modified by BJA86 at 2:17 PM 6/24/2007
Old Jun 24, 2007 | 01:20 PM
94_DC4's Avatar
You don't have to cut the wire. With a razor blade cut off some of the insulation to expose enough wire to allow you to test it. On your car it should be yellow w/green stripe.
Old Jun 24, 2007 | 01:45 PM
BJA86's Avatar
ok kewl i tried the yellow green and its giving me 13.25 car on ofcourse hehe
Old Jun 24, 2007 | 01:48 PM
94_DC4's Avatar
Ok. Now find a good spot for the kill switch and wire it up. Remeber though if you are going to extend the wire more than 3~5 feet you will need to use a relay.
Old Jun 24, 2007 | 01:53 PM
BJA86's Avatar
alright awesome thanx for input
Old Jun 24, 2007 | 01:55 PM
94_DC4's Avatar
No problem.
Old Jun 24, 2007 | 02:30 PM
BJA86's Avatar
awesome works very nice thanx again
CivicMike
Jun 27, 2005 07:18 AM
FastNFurious
Jun 14, 2003 06:42 AM
Trigun
Apr 16, 2002 08:48 AM
