wire locks?
Old Sep 10, 2004 | 02:30 PM
i-CiViC's Avatar
Default wire locks?
Ok I have a 96 Civic and the factory PDL dont work. I have an alarm that can control it. The two wires from the alarm are connected to the switchs LCK/UNLCK wires. still doesnt work. My Question:
How do I wire the alarm to directly control the door lock actuators?? or do I need to add relays so i wont loose switch control?? How do I do either one of these??
Thanks in advance!! I have been burning out trying to get this one- so any help IS appreciated
BTW: I have done the obvious; switch, fuses, actuators(new) PDL Relay(new)
Old Sep 10, 2004 | 03:17 PM
nezfotnemom's Avatar
Default Re: wire locks? (i-CiViC)
the alarm only puts out a pulse and not enough voltage to pop the lock. What you need to do is wire a 12volt relay and connect the lcoks to it.. I will make you a diagram in a few minutes because im at work...
Old Sep 10, 2004 | 03:21 PM
Default Re: wire locks? (nezfotnemom)
Old Sep 10, 2004 | 03:22 PM
you can buy 2 of these relays for like $3 apiece at checker or autozone.. just wire this setup then wire each door lock to the - and + on the relays... worked for me should for you.. good luck
Old Sep 10, 2004 | 04:43 PM
i-CiViC's Avatar
MANNN!! Thanks! this is what Ive been looking for... I WILL be trying this early in the morning!! Thank you!
Old Sep 11, 2004 | 08:01 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have a 96 Civic and the factory PDL dont work. I have an alarm that can control it. The two wires from the alarm are connected to the switchs LCK/UNLCK wires. still doesnt work. My Question:
BTW: I have done the obvious; switch, fuses, actuators(new) PDL Relay(new) </TD></TR></TABLE> unless there is a problem with the oem relay pack you don't need relays
Lock is green/white unlock is green/orange, low current neg. trip, the wires are found at blue 16 pin plug to the left of fusebox. 94
Old Sep 12, 2004 | 08:07 AM
i-CiViC's Avatar
Default Re: wire locks? (fcm)
*****************************update*************** ********
OK! I did the 2 relay override that nezfotnemom suggested It worked and I was almost done when I found that I had to run the wires through the rubber seals on the doors (grommets?). It took a while b/c the 96 - 98 civics have this stupidassshit where the wires dont flow through the grommet- they have connectors! yall prolly knew that though! Anyway! finally got the basterd unplugged and found that the 14g White/Green wire was cut (it's an old cut cause the ends were brown- not copper) This MF wire is the 12V+ for the MF relay!!! Sorry if I seem pissed- cause I am. Dammit i been working on thisshit for a month spent almost $200 for a M...F... broken wire!!! FFFFF
Man thanks for all your time in responses...but I wouldn't have found it if it wasn't for you guys! thanks nezfotnemom, fcm and HT!! HT is the shizzznit
chillerice
Audio / Security / Video
Apr 30, 2013 07:54 PM
m.glisson003
11
Oct 11, 2011 11:34 AM
Boosted_90Teg
Sep 14, 2010 07:41 PM
si90rex
Nov 18, 2008 04:55 AM
