WIRE EXPERTS PLEASE HELP!!!
Old Nov 16, 2005 | 04:13 PM
dajman94's Avatar
Default WIRE EXPERTS PLEASE HELP!!!
***FIGURED IT OUT>>>DON"T NEED ANY MORE HELP***
i put this here cause even though its not audio video or sound it involves wiring and i know you guys have to know something about wiring
LONG POST!!!>>>>BUT PLEASE READ AND HELP ME!!!
ok so the other day i removed my denji angel eye projector headlights and the wiring harness that goe with them that you can see in the pic below. I was doing this in order to trade someone for stock headlights, but that fell through so what i am left with is the one light just like factory eg's but the wiring looks weird, i think becasue of the projector headlights. So i put the projectors back in for the time being until i can sell mine or trade. Well i put the bulbs back andthey wouldn't light at first, so my friend looked at them and told me they needed a ground( he touched the light to some metal and vwalaa, they lit up)so i hooked up grounds to them and now they do not light. Once my friend showed me i kept testing it with the lights on to find a good ground and spot on light and during that i blew a fuse which i found and replaced along with all the headlight fuses for low and high beam.
ALL FUSES ARE GOOD AND CHECKED
CORNER LIGHTS AND FOG LIGHTS WORK
TRIED FLICKING FROM HIGH BEAMS TO LOW BEAMS AND NO GOOD
take a look at these picks and let me know what the deal is and if you have some pics or could take some of a stock wire job, it would be greatly appreciated
HERE"S THE HARNESS THAT WAS REMOVED THAT WAS FOR THE PROJECTORS SO THERE COULD BE A SECOND SET OF BULBS
DRIVER SIDE....LOOK AT THAT BLACK BOX!? IS IT SUPPOSED TO BE THERE?
HERE IT IS WITH THE BOX OPEN
THE BLACK BOXES USED TO BE HOOKED UP TO THE BLACK BOXES ON THE WIRING HARNESS I REMOVED BUT THE HARNESS WAS REMOVED WHEN MY FRIEND GROUNDED THE BULBS AND THEY LIT UP
PASSENGER SIDE.....THERE'S THAT BOX AGAIN AND THIS WIRING IS A LITTLE DIFFERENT COMPARED TO THE DRIVER SIDE....LOOK AT THE WHITE WIRE FOR THE LIGHT
AND WITH BOX OPEN
any info would be very appreciated
I NEED THESE FIXED BY TOMORROW NIGHT CAUSE I DRIVE TO WORK AND BACK AT NIGHT AND NEED THEM RUNNING
Modified by dajman94 at 7:29 PM 11/16/2005
Old Nov 16, 2005 | 05:04 PM
fcm's Avatar
fcm
Old Fart
Default Re: WIRE EXPERTS PLEASE HELP!!! (dajman94)
OK I will try, but all I can tell you is the oem wiring on the "Left Headlight" plug the red/green wire is high beam, the red/yellow is low beam and the black is ground, on the "Right Headlight" plug the red/blue is high beam, the red/white is low beam and the black is ground.
You don't have a good pix of the back end of the lights so I can't be of much help there, other then to say there should be 3 wires off each light, a high and low beam wire and a ground 94
slacks
Sep 7, 2008 11:15 AM
JDMDC2BOY12
Aug 9, 2008 07:17 AM
seer
Lighting
Nov 8, 2007 08:37 AM
dajman94
Nov 16, 2005 04:52 PM
uNF$@#!
May 4, 2002 01:23 PM
