Will AUTOMATIC remote starter work on MANUAL tranny???
Old Jun 8, 2003 | 04:38 PM
Turbo'dMex-A-Keen's Avatar
Default Will AUTOMATIC remote starter work on MANUAL tranny???
I just bought a Prestige alarm w/ remote start and it says it's for automatics. I was wondering if I did the clutch bypass wiring would the remote starter work??
Please any info will be useful..
Old Jun 8, 2003 | 06:08 PM
t0p_sh0tta's Avatar
Default Re: Will AUTOMATIC remote starter work on MANUAL tranny??? (foe-doe-ownin)
Yes it will work, but I am sure that you've heard that it is not recommended 1,000,000 times.
Old Jun 8, 2003 | 06:31 PM
Default Re: Will AUTOMATIC remote starter work on MANUAL tranny??? (t0p_sh0tta)
Yeah i've heard that it isnt recommended but i am one who doesnt leave his car in gear so i wouldnt worry about starting it in gear. Do you know how to make the ecu think the clutch is in all the time???
Old Jun 8, 2003 | 07:42 PM
JeepNintegraGSR's Avatar
depending om the car look by the clutch pedal there will either be a button by the floor or by the top of pedal or both. all you have to do is figure out if they are normally open switches or normaly closed and wire them so the ecu thinks th e pedal is pushed down. i did one on a friends eclipse and all i had to do was unplug the switch on the floor and it worked
Old Jun 8, 2003 | 07:46 PM
Default Re: Will AUTOMATIC remote starter work on MANUAL tranny??? (JeepNintegraGSR)
thanks
Old Jun 9, 2003 | 04:16 PM
rjr162's Avatar
most honda's have two on the clutch... one that tells when the clutch is first pushed in (have no idea what this switch is really for) and one that gets pressed when the clutch is all the way to the floor. That 2nd one is the one you need to jumper
Old Jun 9, 2003 | 05:43 PM
Default Re: Will AUTOMATIC remote starter work on MANUAL tranny??? (rjr162)
thanks man
Old Jun 9, 2003 | 08:20 PM
TrblPinoy1's Avatar
it's hella easy to do...but won't recommed it....
Old Jun 10, 2003 | 08:05 AM
nOOber's Avatar
"one that tells when the clutch is first pushed in (have no idea what this switch is really for"
cruise control - shut off ?
Old Jun 10, 2003 | 01:38 PM
Default Re: Will AUTOMATIC remote starter work on MANUAL tranny??? (nOOber)
yeah that might be it n00ber, i never thought of that.
Old Jun 12, 2003 | 04:36 PM
forcefedcrx's Avatar
look for the 2 wires with a yellow or green harness on the end if them, will be at the top of the clutch pedal assembly, the just take a wire and jumper the 2. THen you can start your car without pushing in the clutch, and enjoy walkinf out to a warm car in the winter.
Old Jun 12, 2003 | 04:47 PM
Default Re: Will AUTOMATIC remote starter work on MANUAL tranny??? (forcefedcrx)
Thanx everyone, now off to jumper my car
no_money2supe
Audio / Security / Video
Jan 18, 2009 08:41 PM
CivicPride97
17
Jan 16, 2008 08:05 PM
lmike6453
Aug 15, 2007 05:58 PM
B18C5er
Oct 13, 2005 12:12 PM
96BlackHB
Sep 20, 2002 11:53 AM
