wierd wiring problem maybe ?
Old Apr 2, 2007 | 05:20 PM
vandersmissenc's Avatar
Default wierd wiring problem maybe ?
ok so here's the story. my clock works when the car is on but it is always reset to 1:00 , my cd player will not start anymore (stock cd player) and my cigarette lighter works. it's not the fuses because none were blown but i replaced them anyway, (backup and cd / cig fuse). i thought maybe it was the constant wire, which i read was the blue with white stripe, so i checked and it seems fine.
my cd player and clock sometimes go out and if i leave my car overnight and come back they work.... it's really wierd. anyone have any ideas or suggestions.
TIA.
Old Apr 2, 2007 | 06:22 PM
fcm's Avatar
fcm
Old Fart
Default Re: wierd wiring problem maybe ? (vandersmissenc)
If the clock resets to 1:00 every time you turn on the ign. it is an indication that the constant power "back up" fuse is blown or the circuit, [wiring] is the problem.
Sorry I do not have a wiring diagram for a ???
If you tested the white/blue, [almost always fused in the under hood fuse box] and it has 12V+ on it constantly the only other possibility is a grounding problem, check your dash harness grounds, most will be on drivers "A" pillar. 94
404notfound
Apr 29, 2014 11:36 AM
Willdrumforfood1
Audio / Security / Video
Dec 28, 2005 04:25 PM
old-sk0ol
Jan 12, 2005 05:27 PM
xSCTYGx
May 31, 2004 08:44 AM
