When you hook up a HU ....
Old Feb 22, 2007 | 09:26 PM
.Thomas's Avatar
Default When you hook up a HU ....
Can you hook it up, like a switch in a wire or something to not come on when you turn the key?.
So when you start your car, your HU does automatically come on, but you can switch it back on if you do.
and not power, because i dont want to re-do the clock all the time
Old Feb 22, 2007 | 09:32 PM
EBP_SI's Avatar
Default Re: When you hook up a HU .... (TanCar)
try rephrasing your question with multiple sentences. right now it looks like a clusterfuck of words that i can't make sense of.
Old Feb 22, 2007 | 09:36 PM
.Thomas's Avatar
Default Re: When you hook up a HU .... (EBP_SI)
re-do
Old Feb 22, 2007 | 09:37 PM
02 accord's Avatar
I think it was clear enough. Yes you can install a switch on the ignition wire and turn it on/off whenever you want to. The ignition wire would only have power when the key is on, so your added switch would only control the line with the key on.
Old Feb 22, 2007 | 09:41 PM
.Thomas's Avatar
Default Re: When you hook up a HU .... (02 accord)
right, would that affect the way it worked?
also, if it was off, could i manually turn on the HU?
like start car ....
wait a little bit, let it warm up
then turn it on, with the power button
(switched off)
Old Feb 22, 2007 | 11:15 PM
suspendedHatch's Avatar
What's wrong with the src button?
Or just get a detachable face.
But yeah, put a switch inline with the aftermarket HU's red wire. It will work exactly as you would guess it would work. On a stock radio, it's the yellow/red wire for most Honda/Acuras.
Old Feb 23, 2007 | 05:15 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">like start car ....
then turn it on, with the power button</TD></TR></TABLE>
Why the hell would you need to do this???
Old Feb 23, 2007 | 05:46 AM
fcm's Avatar
fcm
Old Fart
All HUs come with an on/off switch, [built in]. 94
Old Feb 23, 2007 | 07:00 AM
02 accord's Avatar
When the key is off, the headunit gets no power. So even if you turn your switch on, you're connecting a wire that needs power (HU) to a wire that does't have power (from ignition). With that switch, you would only be able to turn off the headunit when the key is on. You will not be able to turn it on if the key is off. The latter could be done by wiring the switch to constant power, but then you might forget that it's on, and when you leave the car, the headunit would still be on.
Old Feb 23, 2007 | 07:30 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">When the key is off, the headunit gets no power.</TD></TR></TABLE>
Yes it does...
Old Feb 23, 2007 | 09:59 AM
02 accord's Avatar
Default Re: (B18C_EJ8)
You know what I meant.
6genocide6
Nov 28, 2024 03:30 AM
jjos
Audio / Security / Video
Apr 26, 2016 02:09 PM
civic91sief
18
Aug 7, 2010 09:15 PM
dabrat8614
Feb 6, 2005 12:21 PM
PetroGuyX
Sep 22, 2003 05:14 PM
