What wire do i cross for ignition kill switch ?
Old Dec 15, 2010 | 05:52 PM
FTNW's Avatar
Default What wire do i cross for ignition kill switch ?
i have the switch all set up
i just need to know what wire on the ignition i connect it to?
93 civic
pics or vid would help
thanks ht
Old Dec 15, 2010 | 09:23 PM
FTNW's Avatar
Default Re: What wire do i cross for ignition kill switch ?
No help ??????
Old Dec 15, 2010 | 11:50 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
There are better kill switches then the ignition as it is very easy to bypass, main relay, ecu kill and fuel injector are the way to go.
Old Dec 16, 2010 | 09:38 AM
1998GsRIntegra's Avatar
Yes. Even just fuel pump over ignition. If its well hidden it will cause problems for anyone trying to steal it.
Old Dec 16, 2010 | 10:57 AM
FTNW's Avatar
anyone know of a diy for fuel pump cut off ?
Old Dec 16, 2010 | 06:31 PM
I think team-integra has a write-up.
If memory serves me right(which it probably doesn't) the wire you want to splice a switch into is yellow with a green stripe and silver dots.
You should be able to remove the drivers side kick panel to find it. Its one of the wires in the main harness that runs from the drivers side kick panel to the back of the car.
Check team-integra though.
all_motor
Feb 3, 2013 11:30 AM
Ldo
10
Feb 24, 2009 05:15 PM
beastman@
Audio / Security / Video
May 17, 2008 01:05 AM
96electronH
Dec 2, 2007 05:29 PM
99fbpem1
Aug 19, 2007 04:23 PM
