WHAT HAPPEND?
Old Aug 10, 2006 | 01:20 AM
ef9_pr0jekt's Avatar
Default Post No Longer Exist
Modified by ef9_pr0jekt at 9:30 PM 8/10/2006
Old Aug 10, 2006 | 04:03 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: WHAT HAPPEND? (ef9_pr0jekt)
Ok well the fact that you had your radio "professionally installed" is null and void now that you tried to "connect something".
You probably blew your ignition fuse on the radio harness itself. Or your ignition lead to the car.
Old Aug 10, 2006 | 04:11 AM
B18C_EJ8's Avatar
First of all, stop posting in all caps. It's rude.
Second of all, if you're a "noob at audio", you shouldn't be "trying to connect something" since you obviously have no idea what you're doing...
Since you say that it's not the fuse, and I'm sure that you verifed both fuses were good, with a meter or test light, you'll need to determine if you've got power on both power wires going into the deck...
Old Aug 10, 2006 | 08:59 AM
suspendedHatch's Avatar
Default Re: (B18C_EJ8)
Please, never touch your car again.
There's more than one fuse, and they don't necessarily say "radio" on them. On some cars its a dome fuse, a cig lighter fuse, an ecu fuse... my policy is to take a multimeter and check continuity on ALL fuses. That's after I verified that there's no power on the red and/or yellow wire first. Then if you still get nothing, get an inline fuse and run power straight from the ignition harness. But in your case you should take it some where and pay them to do it for you.
Old Aug 10, 2006 | 09:31 AM
fcm's Avatar
fcm
Old Fart
What were you trying to hook up and where?
As has been stated it's probably the HUs acc. fuse, [oem fuse in under dash fuse box, or a fuse on the acc. line of the aftermarket HU] 94
Old Aug 10, 2006 | 09:57 AM
Sorry for posting in caps. I was kind of in a hurry. I thought i said what i was connecting but i guess i forgot . i should be more clear. Alright, well i was trying to install the OEM air vent Clock From my 89 si [the one that is located on the upper portion of the deck]. & so as i was connecting one of the wires from harness [because they were cut], One of the wires accidently touched eachother and made a little spark. I wasn't sure this was the problem. Then after that i realized that my deck was not working anymore. But that was what i was trying to connect. Not inside of my deck area. Thanks for the post guys ! keep them coming.
Modified by ef9_pr0jekt at 9:58 PM 8/11/2006
Old Aug 10, 2006 | 10:14 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">keep them coming. </TD></TR></TABLE>
Seriously, WTF is wrong with you? Did you not read the posts above? There is no reason to keep them coming. People have already suggested the things to check...
Old Aug 10, 2006 | 10:16 AM
B18C_EJ8's Avatar
But since you obviously won't read what's already posted... Here's something else to check. There are some wires under the back seat. Pull the back seat and make sure they didn't vaporize when you made the little spark.
Also, remove your left rear tail light and ensure that the foam gasket is in place. If it's rotted or torn, replace it.
Also, pull off the driver side front splash shield and clean it. That should get your deck working again.
Old Aug 10, 2006 | 11:55 AM
CB7.v2's Avatar
take it back to wherever you had it installed, own up to what you did and hopefully they will be able to figure this out for you.
Old Aug 11, 2006 | 04:07 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Post No Longer Exist</TD></TR></TABLE>
LOL...
Outlaw-Hondaz
Oct 6, 2010 09:02 PM
ScottieA
Audio / Security / Video
Jan 23, 2006 12:01 PM
sashimi
Jun 6, 2005 05:41 AM
antivic
Jun 7, 2004 10:44 AM
